Go to Post Besides, you know hard it is to solder with gloves on? - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 13-04-2012, 21:56
maddz11's Avatar
maddz11 maddz11 is offline
FRC #0702 (Bagel Bytes)
maddz11 is an unknown quantity at this point
How to Make a CADD rose
I'm making a cake on Inventor, in order to keep up my skills. I'm using multiple planes (since it is circular) to attach decorations. I don't care if they are flat but I'm having a really hard time figuring out how I would make a rose.
I thought of lofting it, the loft turned out super weird.
Thanks! (I'm new here, sorry if this is a bad question. Please tell me how to fix it if so)
Unread 13-04-2012, 23:37
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: How to Make a CADD rose
http://home.pct.edu/~jmather/content...orial%2011.pdf
See this tutorial written for a different CAD program.
The process in any CAD program would be essentially the same.
Attach your file here if you run into trouble.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 16-04-2012, 12:20
JD Mather's Avatar
Did you get this figured out?
I can attach an Inventor example if you need it.
Unread 16-04-2012, 17:33
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Rookie Year: 2007
Peck will become famous soon enough
i (as one who didn't know how before) understand this.
and to maddz: welcome to CD
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 20-04-2012, 18:57
maddz11's Avatar
Thank you so much! Let me take a look, I'm still figuring out how to manage notifications so I get replies in a timely fashion. I'll respond if it doesn't make sense.
Unread 20-04-2012, 19:48
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
I made a rose in solid works for 3D printing a while ago. I used surface lofts with splines and spline guide curves to make the petals. Once the surface lofts were done it was easy to thicken them to form a solid body. The base was a 6 sided prism which I twisted and bent to make it a bit more organic. I think that the flex tool as well as surfaces are your best bet for a rose.
