Go to Post ASPCA would be happy to know you are petting your watchdog rather than kicking it. - Ether [more]
Unread 14-04-2012, 16:41
Andrew Lawrence
Posts: n/a
Do you have to use 2x1x1/8" tubing for a WCD?
While I can use it, we've used .5x.5x1/8" steel tubing for our entire superstructure this year and found great success with it. Is there a reason for using the 2x1x1/8" tubing most teams use when making a WCD?
Thanks!
Unread 14-04-2012, 16:45
Joe G.'s Avatar
Joe G. Joe G. is online now
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: Do you have to use 2x1x1/8" tubing for a WCD?
It fits the bearing blocks used for a west coast drive well. But if you can make the design work with something else, there's no reason that you have to use 2x1 tubing.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 14-04-2012, 16:47
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Thanks!
It's the smallest size that can fit a bearing block for a live axle.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-04-2012, 16:53
Andrew Lawrence
Posts: n/a
Thanks!
Unread 14-04-2012, 17:11
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
This is a bit of an aside, but is there somewhere I can look up some detail on these specific bearing blocks?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 14-04-2012, 17:47
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
- Sunny G.
I would just search CD. Everyone does them a little differently, and it's not hard to find pictures and advice.
We tried 1/16" wall tubing on an offseason project for a WCD. It wasn't terrible, but the walls bent in around the bearing blocks. Definitely would not recommend it.
1625 has a nice drive with wider tubes to fit their belts inside the tube. http://www.chiefdelphi.com/forums/sh...ad.php?t=86668
Unread 14-04-2012, 19:41
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
We used 3 by 1.5 by .125 tubes this year for our WCD. They were pocketed with 2 inch diameter circular holes. Rather than slide our bearing blocks rotated in place, having 4 discrete positions to both tension chain and achieve proper center drop. We did this because it moved fabrication resources onto the frame that would otherwise have been devoted to the bearing blocks. We also used the larger tubes because they work a bit better with the rivets our team favors. In short, choose a tube size that works for you, smaller tubes favor teams that weld and use smaller wheels, while larger tubes favor rivets and gussets with larger wheels.
Unread 14-04-2012, 20:07
waialua359's Avatar
Happy Birthday! waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Our team has used 1x3 1/8" the last 5 years.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 14-04-2012, 20:19
Chris is me's Avatar
AKA: Pinecone
We used 3x1.5x1/8" the past two years in order to accommodate our internal belt drive. It's a weight penalty over other frame sizes, but a zero maintenance drive is REALLY nice.
Unread 14-04-2012, 20:20
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
A regular WestCoast with 2x1 is pretty much zero maintenance as well
Also saves you some weight!
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 14-04-2012, 20:31
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
-RC
Correct me if I am wrong Chris. But I believe he means no maintenance as the fact that they never have to tension their belt. On a WCD, you have to maintain it, though a very small job, by making sure the chain is tensioned, and adjusting the bearing blocks when the chain stretches.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 14-04-2012, 21:23
AKA: Pinecone
That is a large part of it. The other factor is that there are no exposed runs of chain to deal with.
I do not think 2791's drive is "better" than a traditional WCD, and the benefits of putting belt inside the tube rather than outside are somewhat marginal, but it works well for us and there is certainly something special about a drivetrain you literally never have to adjust.
Unread 14-04-2012, 22:24
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
1/8" wall for drivetrain, 1/16" wall for superstructure and bumper rails.
Unread 14-04-2012, 20:51
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Thanks!
Now is it steel or aluminum, because steel would get really heavy after awhile.
  #15   Spotlight this post!
Unread 14-04-2012, 21:04
Andrew Lawrence
Posts: n/a
It's steel, but it's surprisingly light. Our entire superstructure this year was under 60 pounds, which allowed us to switch out our entire frame with the steel by our second regional.
