#16
Re: Teams to Watch
Naah, LF doesn't bold their "ands" between teams
#17
Re: Teams to Watch
It will be interesting to see what happens in the dome. There are some high-powered teams that have been relying on vision up to now, and doing that in the semi-translucent dome with changing lighting may be..... challenging.
In addition, the idea that 100, or even 50 teams can get out and tune their cameras at both ends of the field in 45 minutes should result in a very interesting situation. I hope FIRST realizes what they've done there. Each team will get what... 3 minutes per side of the field? Not including moving from one side to the other? |
#18
Re: Teams to Watch
I'm calling Newton being the champions (with 469, 1717, and 330 (I think 330 will be feeding and playing D, though, but another feeder/defender could work)), and Archimedes will be finalists (I see 67, 2056, and another Canadian team).
#19
Though the bond between 1114 and 2056 is well documented and dominant through their careers, the fact remains that both of them are long bots. As we have seen, most dramatically by 148 at the Alamo, those 40 points can be the deciding factor in many cases. I believe that if either of the Canadian Powerhouses rank first they will choose Team 67 for an easier and more consistent triple balance. If 67 manages to grab the top spot, I believe they will ally with the better key shooter, Simbotics, to mitigate the risk of fender-bender defense. If HOT and Simbotics team up its hard to imagine an alliance to top that!
If anyone can, I presume it would be a 987 and 341 led alliance from Curie. Just my 2 Canadian Cents Team 1325 would like to luck to all teams, we will be cheering you all on! ![]() |
#20
Re: Teams to Watch
Archimedes:
1. 67, 2056, 245 - W 2. 1114, 1592, 4001 - F 3. 1218, 2590, 190 - SF 4. 2826, 359, 2022 - SF 5. 1676, 1504, 781 - QF 6. 973, 1261, 1902 - QF 7. 1756, 195, 126 - QF 8. 234, 1311, 1403 - QF Curie: 1. 341, 233, 830 - F 2. 987, 1986, 244 - W 3. 1477, 254, 1678 - SF 4. 971, 624, 51 - QF 5. 525, 1501, 1319 - SF 6. 3098, 78, 2180 - QF 7. 1507, 2474, 3929 - QF 8. 1985, 27, 85 - QF Galileo: 1. 16, 25, 1583 - F 2. 48, 180, 1038 - W 3. 2337, 801, 3322 - SF 4. 33, 148, 1305 - SF 5. 1323, 2054, 125 - QF 6. 1718, 1732, 2169 - QF 7. 573, 399, 2016 - QF 8. 1714, 1918, 772 - QF Newton: 1. 469, 1717, 86 - W 2. 548, 111, 45 - SF 3. 330, 118, 11 - F 4. 1023, 610, 2122 - QF 5. 222, 365, 816 - SF 6. 488, 1662, 375 - QF 7. 1126, 4294, 175 - QF 8. 340, 79, 107 - QF Einstein: Arch vs Curie - Arch Galileo vs Newton - Newton Arch vs Newton - Arch Last edited by dodar : 19-04-2012 at 10:36. |
#21
Re: Teams to Watch
Re: Teams to Watch
Does Newton face off against Galileo first? If so then I take back that prediction. I was under the impression they were playing Archimedes first. |
#23
Re: Teams to Watch
A <--> C G <--> N |
#24
Re: Teams to Watch
I seem to remember it always being Archimedes vs. Curie and Galileo vs. Newton. Has it ever changed in the modern era?
#25
Re: Teams to Watch
But I am rooting for Curie division, hoping they can break that curse. |
#26
Re: Teams to Watch
I honestly believe that there will be two sure divisions represented in the finals on Einstein. Those are Archimedes and Newton.
On Archimedes, despite the history of 1114 and 2056, I honestly believe this year is not a dominant one for 1114, at least compared to their recent history. I think they're a phenomenal team that will do well on the field - and, I might add, are my favorites to enter the FIRST Hall of Fame this year - but I also think Team 67 is the most likely to seed first on that division. If that is the case, the first machine to come to mind is 2056. We've seen HOT triple with long robots before (548 at the Northville District), and I think a 67/2056 alliance could and would win that division. Teams like 359 and 973 will challenge, but it seems to be HOT's to lose. Newton is the other very strong division. Against all odds - at such an event, it truly is a serious feat - Team 469 lost only a single match at the Michigan State Championship. On Newton, they'll be looking to go perfect, and they have the tools to do so. With their effective stinger, too, they'll score coopertition points with ease. If they seed #1, they'll have their pick of excellent partners to play with. Teams 548 and 1717 jump out to me as extremely attractive to 469, and an alliance containing either pairing has the potential to be world champions. This, however, could be upset by many other contenders, including the respectable 118 and consistently-excellent 111. Curie will likely be dominated by Team 341, a robot that has seemed, at times, untouchable; however, with a strong remainder of the field, including perennial powerhouses like 254 and 233, as well as very respectable machines in 51 and 987. As for Galileo...I'll hold my silence. I'll be behind the glass trying to ensure my own team seeds first, but I think that Galileo is the division with the least clear-cut favorites. It should make for an incredible event! Last edited by J_Miles : 18-04-2012 at 22:50. |
#27
Re: Teams to Watch
Re: Teams to Watch
My mistake. I had a conversation earlier surrounding those two teams. Not sure how I made that connection.
#29
Re: Teams to Watch
Out of interest, shouldn't we also take into consideration special devices for balancing? 1986 and 118 have some amazingly effective tools to get a triple balance and I heard 1477 has something as well. Others with assistance are469, 1918(maybe), 610, and others have special lower gears (624) or brakes (118)
