Go to Post It's over, done, let's move on and be positive. Next year maybe everything will be perfect. :cool: - Ed Sparks [more]
Unread 09-11-2001, 10:20
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Question Max mechanical power of motors, how is it useful?
I understand that the maximum mechanical power output by a DC motor can be obtain from the equation:
Pmax = 1/4 * Torque max. * w max. (Angular velocity)
Now, my question is, what is so important about this equation? Is it only used to calculate available power from motors, or can it be used in some other way?
I remember that while controlling the motors, we should always set the mechanical power output of motor a little less than the Pmax... Well, how exactly do we do that?
Do we use the value of power reflected after setting up the gearing, or in another words, do we figure out the the mechanical power after we attach the gears and arms? If so, do this mean that we should use gear ratio to control the mechanical power and aim to design a ratio to achieve a P close to Pmax?
Should we only include the gears when calculating power output, or should we also include the components we use (such as wheel, or arms)?
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
max power/speed for chalupa motors Greg Needel Motors 0 14-01-2002 09:56
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
Drill Motors TF8 Motors 19 12-12-2001 13:13
