Go to Post And then, at the end of the match, the drive teams who are being lifted all say at once (in a GOVERNATOR voice)- "GET TO ZE CHOPPER!!!" - Graham Donaldson [more]
Unread 19-04-2012, 19:41
CyberEagle9416's Avatar
CyberEagle9416 CyberEagle9416 is offline
FRC #2073 (Eagle Force)
Rookie Year: 2010
CyberEagle9416 is an unknown quantity at this point
T-shirt Cannon revolver seal
our team is trying to make a t-shirt cannon with a revolving barrel. does anyone know how to seal the barrel each time the barrel rotates?
Unread 19-04-2012, 19:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: T-shirt Cannon revolver seal
No need, at least in our experience. There is some air loss but the plate that backs the barrels is a close enough fit that it's not a big pressure drop.
2001-2004: Team 100
2006-Present: Team 254
Unread 19-04-2012, 19:50
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
You should ask 706.
Unread 19-04-2012, 21:41
JV2073's Avatar
JV2073 JV2073 is offline
FRC #2073 (EagleForce)
Rookie Year: 2010
JV2073 has a spectacular aura aboutJV2073 has a spectacular aura aboutJV2073 has a spectacular aura about
Hi, I am a part of the team that is creating our second t-shirt cannon for team 2073. We are currently designing on solidworks and started to realize some major problems. We are trying to figure out how to control the scuba tanks and the part that is needed as a solenoid. We would like to know how to control the scuba tanks high pressure. Thanks
Unread 19-04-2012, 21:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
YOu need a pressure regulator, as well as a large diameter solenoid valve. and probably a second storage tank, and another solenoid valve (at least that's how we did ours years ago)
Unread 19-04-2012, 21:54
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
I recommend a sprinkler valve, our T-shirt Cannon uses one.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 20-04-2012, 01:11
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
I would not recommend a sprinkler valve, just because I've read threads suggesting the same and concerns about how safe it is.
We based off our T-Shirt cannon off of 254's Shockwave and like Squirrel mentioned
We did the same. We have a 3000 psi SCUBA tank connected to SCUBA valves that run to a 5000 psi pressure gauge and 150 psi regulator (this is the outlet for the pressure for the diver). We then adjust that regulator from 40-150 psi depending on the venue we are shooting in (small or HUGE). The air from the regulator fills a secondary SCUBA tank that accumulates the air for each shot at a much safer pressure than the main 3k psi SCUBA tank. The solenoid that lets out the accumulated air for each shot is a 1" NPT MAC solenoid, similar to the one on Shockwave.
We have a gap of about half an inch (yes I know it's quite a bit) between the exhaust valve and the barrel but the maximum range is still about 200 feet.
2009 Hawaii Regional Rookie Inspiration Award
2010 Hawaii Regional Chairman's Award
2011 Hawaii Regional Entrepreneurship Award
2012 San Diego Regional Entrepreneurship Award
2012 Hawaii Regional Entrepreneurship Award
2012 Hawaii Regional Chairman's Award
2012 World Championship Judges Award
Unread 20-04-2012, 16:32
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
GRT808 Can you post some pictures.
Our revolver has been upgraded with a scuba tank as well. We have the scuba regulator fixed at 120 psi and have a second regulator (standard FRC regulator) that adjusts pressure into the accumulator tank at no more than 60 psi and we have a third regulator that adjusts pressure into a small accumulator tank that operates the modified 3/4 in gate valve we use to fire the contraption.
Our revolver seals are spring loaded pvc on both sides of the revolver cylinder and only open up about 1/8 inch when firing. We get about, never measured it but probably about 100 ft at max elevation. We do have 10 shots though and the accumulator tank refills in less time than it takes to rotate another shot into place.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 23-04-2012, 02:09
GRT808's Avatar
AKA: Grant
Found it! Sorry it took so long. In the picture it looks a bit bad...but it works. Check it out on youtube sometime. (and in our chairman's video)
