Smart dashboard Camera Problem
Greetings!
I'm trying to get the smart dashboard to connect to my M1011 camera. I've set the IP address of the camera in the properties, but I still am not seeing any video. There's only one network involved (the camera is plugged directly into the wireless hub). I can see the video in a browser to the same address, so that's definitely working and available as an anonymous access. Is there some additional user ID or credentials that I need to specify to get the video working with the smart dashboard? TIA, Mike |
Re: Smart dashboard Camera Problem
Yes, you need to enable the anonymous preview feature on the camera. This is a separate feature than simply being able to view the live stream via the web admin interface without logging in.
I don't recall the exact submenu, but there is a checkbox for it in the web admin interface on the camera. Once enabled, your SmartDashboard camera feed should start working. Last edited by Mr. Lim : 20-04-2012 at 01:40. |
Thanks! Mike |
Mike |
