Go to Post I think these new rules are making the message coming from FIRST perfectly clear - engineering is about what happens between your ears, not what comes out of your deep pockets. - KenWittlief [more]
Unread 21-04-2012, 15:24
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
WCD-Style Belly Pan Weight
After cadding up a 1/8" 6061 "WCD-style" belly pan, Inventor calculated its weight to be around 5.2 lbs. Would anybody consider this to be an accurate measurement? Assuming it has a diamond/cross hatch pattern similar to the ones displayed in this thread and encompasses the entire bottom part of the drive base.
Strictly in terms of weight, 5.2 lbs is around a pound lighter than the 1/4" unpocketed polycarbonate sheet that we used this year and had no problems with.
Unread 21-04-2012, 15:44
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: WCD-Style Belly Pan Weight
Sounds reasonably correct. My team used a 1/16" belly pan (5052 aluminum) this year with no pocketing and it weighed 5 pounds. Assuming you're using something like 6061, 6063, 5052 depending on the size and how much pocketing, 5.2lbs is reasonable for all of those.
Unread 21-04-2012, 15:53
Borobo Borobo is offline
AKA: Patrick
FRC #0159 (Alpine Robotics)
Team Role: CAD
Rookie Year: 2010
Borobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really niceBorobo is just really nice
What our team has used for the last few years is a type of plastic extrusion called veralite it's really light, but if you mount it so that the grain of the plastic cells is right for the load, it can be way more rigid than polycarbonate sheets. for example, out bellypan this year for our WCD was about .3 pounds. it's also easy to drill holes in for zipties and other wire routing hardware.
Unread 21-04-2012, 17:14
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
We did 1/8" 5052 on a prototype with a ton of pocketing, and it came to 4.5lbs or 5lbs. One of our main reasons for the bellypan is keeping the frame stiffer in torsion. Have you found any advantages to 1/16", especially if the weight is about the same as pocketed 1/8"?
Unread 21-04-2012, 20:29
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Also, remember that a belly pan the one of the closest things to the ground on any robot. This helps lower you CG, which is really important in most games, and very important on any 6 wd bot. Furthermore, with lightening, it allows you secure attachment of electronics, and stiffens the whole frame. Therefor, it is worth the weight to invest in a bellypan.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 22-04-2012, 00:40
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
i havent seen a west coast drive bot with this but i'd think polygal would work a bottom pan.
Unread 22-04-2012, 01:08
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Our belly pan this year on our 2012 robot is ~2.5 lbs. We could've made it a little lighter. We added/left material where we thought we would need it for mounts/stingers in the feature.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 22-04-2012, 01:14
Rookie Year: 2010
-RC
What material is it?
Unread 22-04-2012, 01:21
Fairly positive its just 1/8" 6061.
Unread 22-04-2012, 02:29
R.C.'s Avatar
Aluminum - 6061 - 1/8" Thick
-RC
R.C.
Unread 22-04-2012, 02:47
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
We went with wood after our aluminum bellypan (much like the one shown above) turned out to be about 5 pounds, which put us overweight. The wood performed great and was much lighter than the metal after we gave a freshman a two inch hole saw. In the end it weighed between 2-3 pounds.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 22-04-2012, 08:59
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
This has come up many times in the past and I always respond with make a composite belly pan. From a mentors view making the belly pan - electronics board from composites is an excellent way to introduce students to the mystical world of composite construction. What our team does is take a 1/4 " , 4mm or 6mm piece of birch ply wood and laminate both sides with 5.7 OZ plain weave carbon fiber using vacuum bagging methods. It's not that hard and is doable by most teams. 11 of our student got hands on experience this year. All though keeping the students focused and neat, not making a gooey mess can be quite mentally draining. The end product is a wonderful material. I can provide some link if needed or search youtube, there are some good videos on it.
Unread 22-04-2012, 20:20
Not a kebab
Rookie Year: 2010
-RC
Wow, our cheesing patterns must be very different then...
Unread 23-04-2012, 00:20
R.C.'s Avatar
When you get a chance, send me a solidworks file.
I'll take a look at it for ya!
-RC
R.C.
  #15   Spotlight this post!
Unread 23-04-2012, 02:44
tzjin tzjin is offline
AKA: Tony Jin
FRC #0192 (Gunn Robotics Team)
Team Role: Leadership
Rookie Year: 2010
tzjin has a spectacular aura abouttzjin has a spectacular aura abouttzjin has a spectacular aura about
Hi R.C.,
Would you mind posting a CAD of 1323's belly pan? I would love to see how we could improve ours! 2.5 pounds is amazingly light.
With a smile,
Tony
