Go to Post Some High School students understand safety and can follow complex instructions. - DonRotolo [more]
Unread 23-04-2012, 08:55
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Re: Plactions treads and rubbing alchohol
Originally Posted by Wing View Post
For the teams that have used the Blue Nitrile tread, how do you cut the tread down to a width that's manageable? I see 3" ad the minimum width, and I'm pretty sure 3" will be too much for manageable turning.
When I was on teams who used this material we always marked the back side of it and cut it tread side down on a bandsaw.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Unread 23-04-2012, 09:01
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
The few times that I've cut Blue Nitrile, I've used a bandsaw as well. I've found that the only way to get a remotely straight cut was to clam a piece of angle (or other material) to the table of the saw to act as a guide.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 23-04-2012, 09:35
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I was hoping to avoid using a bandsaw... My shaky fingers often mess up cuts, and those burs really are annoying. How much more advantage does Blue Nitrile have over roughtop or Colson?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 23-04-2012, 09:38
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
We often use a box cutter or razor blade (along with a clamped-down straight edge) to cut our tread to length and width. It isn't too difficult.
Based on qualitative observations (and a few quantitative experiments), blue nitrile outgrips Colson wheels on carpet (particular with wide, small diameter wheels), but on HDPE and polycarbonate surfaces, the Colsons grip a bit better. Adding custom tread patterns to the Colsons supposedly closes the gap with roughtop tread on carpet.
Unread 23-04-2012, 09:42
Andrew Lawrence
Posts: n/a
I hear it's pretty grippy, and wears really well....but that's it. If you get into a pushing match with roughtops vs. nitrile, both with similar gearboxes/speeds, you're not going to find one will be drastically better than the other.
If you don't think it's worth the hassle, just use roughtop/colsons. You're not going to loose any needed power.
Unread 23-04-2012, 09:54
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Just to clarify. Nitrile is a material while roughtop is a tread pattern. You can get nitrile roughtop or neoprene roughtop or a couple other rubbers. Nitrile is just about the least grippy of all the potential materials but not by much and its wear characteristics are much better than some of the other materials. That said...I still prefer colsons.
Mentor 2415
Unread 23-04-2012, 09:58
AKA: noops
Originally Posted by sdcantrell56 View Post
....That said...I still prefer colsons.
Of course, the only thing preventing me from using colsons is the time and financial cost of making your own live axle hubs for them.
