Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Unread 21-04-2012, 21:35
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
Modify camera fps on default dashboard?
How does a LabVIEW-illiterate person modify the camera fps on the default dashboard? If I double-click on the Camera-Read_MJPG icon the WPI_CameraRead MJPG.vi:1 (clone) window appears. I can change the fps under Camera Settings from 30 to 10, select File/SaveAll, then save the Dashboard Main.vi. But when I exit LabVIEW and check the fps again it has changed back to 30. So how do you change the fps and get it to stay put?
Unread 21-04-2012, 22:18
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Modify camera fps on default dashboard?
It's the clone part that's making trouble for you, since it's only a copy of the original.
It's an unused input, so you could just give it an input.
Otherwise, to make your new default values stick you'll need to change the original. That's going to be found from the Project Explorer window under Dependencies->vi.lib->WPI_CameraRead MJPG.vi
Make the change there, then use Edit->Make Current Values Default for it to stick.
Unread 21-04-2012, 22:38
Thanks, that works. I would have never found that.
So now I see it has changed in the Dashboard Main.vi. I can select Tools/Build Application (EXE) from VI... and then rename and copy the new .exe file to the FRC Dashboard folder. Correct? It also generates .aliases and .ini files. Do these need to be copied also?
In addition to this change I have also enlarged the video window to make it easier for the operators to see. That works very well.
Unread 21-04-2012, 23:43
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
Rookie Year: 2011
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
No. you only need the .exe file.
2009 Regional Winners
2011 Regional Chairman's Award
2012 Regional Winners
2013 Regional Chairman's Award
