Re: Possible Lower Scores on Einstein?
I expect to see Titanium on Einstein play a 115+pt match.
If this plays out, those starved balls need to be turned into human thrown buzzer beaters. What a way to decide Einstein... if both alliances decide to starve. Both triple balance, and there's a wealth of balls in the hands of the human players with <30 seconds left... P.S. I'll never get any work done... this thread has made me revise my pre-scouting pick list AGAIN... Alliances running this strategy only need to shoot twice the entire match: once in hybrid, and once near the end of the match before triple balancing. Strong hybrid, excellent ball-pickup, steady high-percentage shooters immune to heavy defense, fast triple balancing, and a human player who can make shots. Last edited by Mr. Lim : 23-04-2012 at 00:29. |
I would have to say, that would be an uneventful Einstein if it were to happen, but this is the top level. Starving is expected to happen, but I would imagine an inbounder that is good at the cross barrier pass will be high in demand.
Especially since teleop scoring is the 4th order sort for seeding, I could see this being employed on A,C,G, and N - not just Einstein. A strategy-minded, quick-balancing rookie could make a lot of noise this way. Last edited by Taylor : 23-04-2012 at 09:41. |
9 points. With the simple solution being to defend your own bridge and force G28s as well as G25s.
Consider a robot, probably wide-body, facing its own bridge and tipping the bridge toward it while remaining on the playing floor. Its alliance can pretty much fill this "funnel" full of balls, and especially if the robot is in its own alley, the balls are untouchable without a flood of fouls. When it comes time to balance, the robot simply backs away, and the other two alliance partners can balance unobstructed from the other side. The first bot can either traverse the bump or climb the coop bridge to the other side. Even if the opposing alliance get those balls, they'll have to score enough to counter the 40-pt triple balance. |
#10
This whole ball starvation strategy is a red herring.
Human players are GOOD and getting balls back across the field under the assumption they're not under a time crunch. Yet bots on Einstein will be GOOD at making rapid shots (think about the 2056-1114 pair with their back-and-forth shots). Here's a partial strategy from my playbook, codenamed "Bunker Buster Bomb": Scenario: Ball starvation strategy, 5-6 balls behind each player station, other balls are scarce. 1.) Our human players slam our balls across the field in rapid succession 2.) Our alliance rapidly scores 6 balls from 2 bots, concurrent with step 1 3.) The 2 bots that scored split up: 1 bot goes for the balls that crossed the field, 1 bot blocks the opponent's throwing lane 4.) 3rd bot scores 3 balls, concurrent with step 4 Probable points in 20 seconds from a MSC/MAR-esque finals alliance: 24, plus penalties because the opponents didn't get balls out in time or had more than 2 balls/player. I seriously doubt the bots will be hungry for long. The alliance that starts this sequence first has the upper hand. |
#12
I just thought of something... the bridges on Einstein, unlike those everywhere else for the last couple weeks, will be completely new, and I've heard that new bridges can be quite slick. Is that true?
#14
Another variable i just thought of that may affect shooting accuracy, this may not affect it as much because of all the stadium lights are the same but do you think different lighting could affect robots, and do you think they may compensate for this by letting teams calibrate cameras for 15 mins?
#15
