Go to Post [Goals For 2012] 1. Build on 20 years of hard work. 2. Inspire a new generation so they come back another year. 3. Repeat. - Koko Ed [more]
  #16   Spotlight this post!
Unread 07-04-2013, 13:53
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Take-Back-Half Shooter Wheel Speed Control
Originally Posted by tr6scott View Post
The code is labview, more info from this link. http://www.chiefdelphi.com/forums/sh...d.php?t=113954
Doh. I remember our conversation now. I am starting to show my age. Sorry 'bout that.
  #17   Spotlight this post!
Unread 07-04-2013, 14:59
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Me too. NP.
The sooner we get behind schedule, the more time we have to catch up.
  #18   Spotlight this post!
Unread 03-04-2014, 22:14
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
Rookie Year: 2013
The Doctor is on a distinguished road
I have found this to be an acceptable take-back-half algorithm:
Code:
cval -= (cval - goodval) / 2;
Where cval is the current value of [whatever] and goodval is the ideal point (what you want it to be at)
Code:
cval += constrain(-(cval - goodval) / 2,-max,max);
This also works, but is constrains the value to within a maximum speed, the variable max. Function constrain below:
Code:
float constrain(val,min,max) {
          return val>max?max:val<min?min:val;
This seems a lot simpler than the previously posted code, and I was wondering if they are equivalent?
  #19   Spotlight this post!
Unread 03-04-2014, 23:29
Ziv Ziv is offline
Has code to be writing...
FRC #0125 (Nutrons)
Ziv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of lightZiv is a glorious beacon of light
Code:
Where's the feedback here? How do you find goodval? The fact that you're setting cval suggests it's an output, and if you somehow knew the ideal output (namely goodval) then you wouldn't need closed loop control in the first place.
Now, if you instead have
Code:
cval -= (sensorval - goodval) / 2;
which seems to be what you were getting at, then what you secretly have is an integral controller (just the I from PID) with coefficient 1/2.
  #20   Spotlight this post!
Unread 04-04-2014, 12:01
Ether's Avatar
Rookie Year: 1969
Code:
Yes.
And, just because it's an integrator, and its gain is 1/2, does not make it a TBH algorithm. The hallmark of TBH is the unique way that the output is reset at each zero crossing.
