Go to Post I still have 3 good ligaments left and 2 events, so I should be fine :rolleyes: - esquared [more]
Unread 26-04-2012, 10:59
Alchemy99's Avatar
Alchemy99 Alchemy99 is offline
AKA: Josh Cote
FRC #3141 (Team Alchemy)
Team Role: Leadership
Rookie Year: 2007
Alchemy99 is an unknown quantity at this point
Send a message via AIM to Alchemy99 Send a message via Yahoo to Alchemy99
Pressure Testing Rig.
Ok, i am trying to prove that a connection can support the air pressure (its not 100% FIRST Robotics)
im drawing a blank when it comes to how to prove it. I have attached a general drawing of what im trying to accomplish. but i have a formed container, that looks like a glass beer bottle, and im trying to pressure test the bottom of it. im looking for a seal that can slide into a .8" id hole, and than expand out to about 2.25" and hold the seal against 125 psi of air.
thank you for any help. im sorry if its in the wrong forum.
Unread 26-04-2012, 15:12
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: Pressure Testing Rig.
I have a lot of questions about why you would be doing it this way, I suspect is has a lot to do with function that may be proprietery. Without trying to run through a full review of your design here, since you are local in CT, I would recommend working with a company that specializes in pressure testing that is in Agawam, MA. The name of the company is RonMar.
http://www.ron-mar.com/
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
