control system programming
Posted by Jimmy Holmes.
Coach on team #27, Team RUSH, from Osmtech Academy and DaimlerChrysler. Posted on 3/2/2000 6:26 AM MST I hope the vast FIRST community can help us with this problem. We are trying to run two van door motors at the same time using two different speed controllers and two different pwm outputs on the controller. The problem is they run at two different speeds and cause our arms to go out of alignment.We had them variable, running off of the same joystick ( pull back they both go up, push forward they both go down). To solve the problem we made the joystick act like a switch and changed the max values so they would run at the same speed, but know it is very jerky, (on off, on off). We want to be able to be variable again but still adjust for the different speed motors. Is there a routine that we could run in the program that could account for the difference? We know its not a friction issue just the motors are not the same. I would like to thank you in advance for any help. Jimmy Holmes Team27 |
| Need a FIRST Robotics control system | kershawrobotics | General Forum | 3 | 07-07-2003 09:49 |
| control system worth more than $500 | archiver | 2001 | 8 | 24-06-2002 02:00 |
| New Innovation FIRST control system and the dashboard | archiver | 2000 | 0 | 23-06-2002 22:15 |
| UNFAIR ADVANTAGE for CDI and new control system | archiver | 2000 | 6 | 23-06-2002 22:13 |
| Ok, how much is the control system worth? | archiver | 2001 | 6 | 23-06-2002 22:05 |
