Go to Post At the end of the day, it really isn’t about the awards. - JesseK [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:14
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Hey FIRST Junkies get your fix and see the action at KSC!
Posted by Mike Sklar.
Engineer on team #21, ComBBAT , from Astronaut H.S. and Titusville H.S. and Brevard Community College and Boeing Company and NASA-KSC.
Posted on 3/2/2000 1:27 PM MST
The KSC Regional, 1 of the first 2 of the season will be broadcast live on NASA Select all day Saturday,
March 11! There may even be some coverage on Friday. Many of you get the NASA select channel on your cable systems already. If you're not sure call your cable company. The NASA Ames folks may in fact rebroadcast the live signal over the web. If so I'm sure they will let you know. If you have a satellite dish and would like to get the broadcast directly the info is:
NTV is broadcast on GE-2, transponder 9C, C-Band, located at 85
degrees West longitude. The frequency is 3880.0 MHz. Polarization is
vertical and audio is monaural at 6.8 MHz.
You can also pick up NASA TV on the web at the link below.
Thanks to NASA for this! They have become an incredible supporter of the FIRST program. The agency is sponsoring
4 regional events this year and helping numerous teams.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
