Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 10-06-2012, 17:08
Banderoonies's Avatar
Banderoonies Banderoonies is offline
Team Mentor
AKA: Sandra
FRC #0195 (Cyber Knights)
Team Role: Leadership
Banderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of light
Re: 2013 Game?
I'd like to see something original. Maybe large scales and various weights around the arena. As the weights picked up by the Bots and carried to the scales it rises a water level in a tube or something like that.
Sandra
Unread 10-06-2012, 17:25
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: 2013 Game?
inb4cries of a water game
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 10-06-2012, 19:46
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: 2013 Game?
Eric and I actually came up with a game that the GDC can use for a water game. Which is more then I can say for anyone else.
Main Game: There are several lunacy like goal weighted down on the bottom of a pool. 1 or more robots on a 3 robot alliance must go underwater to pick up at least one of the goals. the remaining robot(s) must score balls filled with a substance less dense then water so they float. each ball scored would be X amount of points, they must remain in the basket until the buzzer to be counted.
End Game: X points are awarded per ball to any alliance that can then take their basket(s) and set them upside down on the bottom of the pool.
Alternate End Game: X points are awarded to each Robot that hangs on a bar(s) located in the middle of the field. Bars are X distance from the water. Robots must be completed out of the water to count.
I haven't thought up an autonomous yet. Ideas?
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 10-06-2012, 20:10
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: 2013 Game?
I've cut out most of the post due to length, but I must ask one question: How deep is the pool? 3"? 3'? 8'? And how big of an area will it cover? Think very carefully about all the implications before you answer.
The reason is this: You have to move the entire pool into and out of the venue. (Unless there's one already there, which I highly doubt.) You also have to avoid damaging stuff that's already there. And there are other things that I could go into.
tl;dr: There's a reason nobody's seriously proposing a water game.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-06-2012, 20:22
JosephC's Avatar
Rookie Year: 2011
Re: 2013 Game?
Answer 1: Average swimming pool size I suppose.
Answer 2: I personally believe that First is slowly switching to venues to have pools. In Michigan this year our newest district competition was at Northville. Northville has a swimming pool, the previous venue did not. And Saint Louis does have a river...
Referee: 2015 - ?
Unread 10-06-2012, 20:47
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: 2013 Game?
I think that switching to venues that happen to have pools is a coincidence. FWIW, most high schools in the U.S. would have a pool (or have one nearby), but would also be cheaper to put a FRC event in than a sports arena. With FRC moving to more events for less money, it just makes sense to go to cheaper venues. Whether said cheaper venues have a pool or not at that point is a non-issue--it just turns out that way or not.
But here's the kicker: if the pool is in the Midwest, it's going to be either indoors or empty during competition, something about winter and pools not being filled during winter if outdoors. If the pool is in the South or Southwest, there's at least a 50% chance if not much higher that it'll be outdoors! That introduces a whole new dimension to the game, known as weather, which in some areas of the country could result in everybody watching getting soaked by rain or heavily sunburned. Plus you get varying lighting conditions, debris "on" the field, you get the picture. And oh, yeah, throw in some rather annoyed swim teams because there went their practice space for a week (gotta set up, gotta remove all debris afterwards, and don't forget to check all the chemical levels).
Also, in 2008 the Los Angeles regional shared a venue with a "pool". It should be noted, however, that the venue was double-booked that weekend. (And there were some not-too-happy teams due to the resulting crowded pits.) The following year, the regional moved to across the street from a harbor. No water game yet...
Past teams:
Unread 10-06-2012, 20:59
JosephC's Avatar
Rookie Year: 2011
Re: 2013 Game?
It's just a joke of course. To feed the "Water Game" hype.
However, to deal with the weather, just put a tent up over the pool. We just played at IGVC this weekend in 90 degree weather.
Referee: 2015 - ?
Unread 10-06-2012, 21:14
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: 2013 Game?
I have to say, a tent over the pool might help... but it depends on the type. Also see "Epcot parking lot pits" and "It comes in anyway" for an enclosed or a popup, respectively.
Past teams:
Unread 10-06-2012, 23:39
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Re: 2013 Game?
After all these years thinking that a water game would be a boon for a swimmer, I just realized that it would involve kicking me out of my pool for long periods of time! I suppose build season does this anyway...
There are many weird sports that have yet to be emulated by an FRC game, but Swimming/Water Polo always seems to come up more than the rest in 20xx game threads. Why don't equally improbable sports like rock climbing or dirt biking, for example, get the attention that the mythical "water game" always seems to?
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 10-06-2012, 23:45
JosephC's Avatar
Rookie Year: 2011
Re: 2013 Game?
They might actually happen. It would remove the "mystical" part.
Referee: 2015 - ?
Unread 11-06-2012, 09:39
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Rookie Year: 2012
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: 2013 Game?
A. It was a thought we joked around with at lunch after a demo one day, not something we actually expect to happen.
B. SPELL MY NAME RIGHT! I'm on your team.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 11-09-2012, 21:34
Freeloder123's Avatar
Freeloder123 Freeloder123 is offline
AKA: Daniel Lopez
FRC #4091 (Team Drift)
Rookie Year: 2012
Freeloder123 is an unknown quantity at this point
Re: 2013 Game?
where do you find the speech ?
Daniel Lopez
Unread 11-09-2012, 21:55
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Re: 2013 Game?
No game piece could be more shamelessly recycled than the tetra. On top of that, what new stuff can you really do with it? A mashup of Frenzy with odd game pieces could be entertaining. I like the idea of "physical challenges" the robot has to perform on an object to pull itself up, stack other robots, or balance itself as the endgame portion. They could theme it to a mission to Mars where your alliance has to collect resources of various shapes, sizes and values into 2 of your alliance's movable bins, and doing something like putting the bin on your robot gives you bonus/multiplier points. 2 bots balancing one bin each receives x points, one bot balancing two bins earns y, and spilling your bin earns you a z penalty.
(Doesn't this work better in the Rumor Mill?)
Unread 13-09-2012, 17:19
PVCpirate's Avatar
PVCpirate PVCpirate is offline
FRC Data Nerd
AKA: Anthony Jennings
FRC #1058 (PVC Pirates)
PVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud ofPVCpirate has much to be proud of
Re: 2013 Game?
I think this thread has become such a staple on CD every year that no one has a problem with it being in the general forum.
My accomplishments with 1058:
2010 - Granite State Regoinal Winners, Galileo quarterfinalists, IRI quarterfinalists
2012 - GSR Chairman's Award winners
An incredible four years I will never forget
  #15   Spotlight this post!
Unread 15-09-2012, 00:35
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: 2013 Game?
Since the GDC is so big on cooperation, I think it would be cool, if robots had to pass game pieces from one to another to score. Nothing more specific than that right now.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
