| View Poll Results: If you have won an event in 2012, did you build and use a practice bot? | |||
| YES |
134 | 74.03% |
| NO |
47 | 25.97% |
| Voters: 181. You may not vote on this poll | |||
Re: Poll on winning teams using practice bots
we have built a prototype for the past 5 - 6 years.
we first build prototype parts and small systems, then get them sorted. then we build a prototype robot, based on the emerging design we are creating. we build it with the intent to be funcationally equal, but it is often heavier and uglier than the competition robot. it has extra holes, used parts, etc. After it is built and tested, we then finalize the design and buid the competition version. we have learned to go back and rework the prototype to make it work like the competiton robot where it is needed, otherwise there can be subtle differences that can cause great pains. it also makes building the competition robot faster and it is more durable because it only has to be assembled once, since all (most ) of the lessons are learned on the prototype. |
There is no doubt that our on field performance has increased significantly since we started building a practice robot three years ago.
We benefit from all the things that have already been stated but there are also intangibles that building a practice/prototype brings. It compresses your build time so you can actually build two robots. This forces you to make decisions quicker and be much more organized. It also makes you raise more money which in itself brings other benefits. I have yet to find a downside to it. |
We built a basically identical un-painted robot this year as a practice robot.
This year we used the practice robot to: -Practice match driving (2:30 runs) -practice specific manuvers including double and triple balancing, jumping over the bump and downfielding balls, and of course aiming and shooting under heavy defense. -improved targeting and shooting software -developed both a center and side bridge auto that shot 4 balls. We also make every change we ever plan on making to the comp. robot to the practice robot first to see how quickly we can do it, any problems that may arise, and if we actually like the changes we are thinking about making. These are those changes from this year that I can remember off the top of my head: -improved internal ball guides into the throat. -sped up external collector. -Changed front drive wheels for better turning proformance (twice) -Changed gearing from a AM 1:4 to the 1:2.54 and modified final chain reduction from 24:12 to 22:12 -moved battery mount to front of robot to move CoG forward. -Took antibackdrive pins out of window motor (for turret) -Made many fang profiles (for getting over the bump) -Shimmed out our bumpers 1/2 of an inch in the front to accomadate new fang profile. -Moved our hood articulator to accomodate starting the turret backwards for auto. -Moved a pot for the collector/bridge manipulator that was giving us trouble to a better location. -put a ball sensor in the throat of the robot to sense balls immediatly when they went into the robot. -many others. It is also worth noting that a simulated field (or actual field) is very important to getting solid practice out of a second robot. Most of the powerhouse teams that build practice robots also have full fields to practice on. Regards, Bryan |
Yes many of the top performing teams have a full field. Most have a 1/2 to 3/4 field. |
We won both Philadelphia 2011 and Hatboro-Horsham 2012 & MAR Championship 2012 with a practice robot (and a roughly full field, though we could have shrunk some). It definitely helps a lot, including driving, programming (both hybrid period and autonomous assists in teleop) and mechanical improvements. I think the biggest thing it's made us do is build more quickly, though. We're still not fast enough, but it's getting there.
We always want to build the practice bot first, but in 2011 we got them done at the same time (seemed impressive then), and in 2012 we finished it around a week after bag & tag. Our goal for 2013 is to get it built first, at least in terms of each system. |
I voted yes to the poll. We did had a practice robot that was very benificial to our programming team before and during the season. It was disassembled before we headed to St. Louis for spare parts.
We have built practice robots in 2005, 06, 09, 10, 11, and 12. Sometimes they are useful for driver practice, programming, etc...other times they are torn down for spare parts because they are not being used during the season. One of the biggest benefits we get out of the practice bot is that we learn what works an doesn't work, in terms of design, manufacturing, and assembly as we build the first robot. This helps improve the quality of build between our practice robot and our competition robot. I would suggest building a practice bot if have time and funding too and you are going to use it to improve before and during the season. Do not build one if it is going to effect the build quality or completion of your competition robot. Competing in Michigan we get lots of driving experience in matches. We did not practice at all in 2009 or 2010. Actually the practice robot in 2009 was torn down before the season to fix the competition robot. In 2010 the practice robot was used for driver tryouts (before the grabber was installed), then we competed in week 1...so no more practice was conducted. In 2011 we practice a couple of times before the season, but never in the season. This year the practice bot was identical and fully functional. We practiced a couple of times before the season. Once before Waterford. Once before Northville. And, then we practiced triple balancing before we left for St. Louis (so much for that.. ). We have about a 1/4 field that we setup and teardown everytime we want to practice. It usually takes about 10min to setup. This setup works for us...it may or may not work for your team. I judge if we need additional practice by comparing ourselves to the rest of the teams out there, if more is needed we do it, if not then we don't. As my good friend JVN says, your mileage may vary... Last edited by Adam Freeman : 01-05-2012 at 10:35. Reason: screwd up the quote.. |
Since 2010 Wave has completed an identical practice bot. I will echo all the words said before and add, I can't imagine not having a practice bot to, well, practice with. The human element of this game is the most underdeveloped an often over looked aspect of the game. Even the powerhouse teams could have the best machine in the world and with no practice, fail dismally.
In 2011, Wave had a phenomenal year with well designed, well executed, piece of junk, will never, ever do again octocanum drive. The ONLY reason we did well with a sub-par drive was that our drive team spent literally 312 collective man-hours finding a way to "make it work" before champs. That being said, we are extremely lucky to have to sponsors we have. Muza Metal Products builds absolutely every sheet metal part we ask for for 2.5 robots. Without them, we would have to scramble even more than we do Triangle Manufacturing (the same company that provides KOP Lazy Susans) machines any custom parts we need and has EDM capabilities which is great for gear manufacture CR Meyer provides half a hangar where they keep one of their planes. We use this for a full plywood field setup. BTW, we had to work our butt off to get and keep such great sponsors and we are fortunate to have such great partners. Dang Adam, rub it in... Why was it so easy on the practice field? (balls fists in frustration) |
103 constructs a full sized field every year. I can tell you from personal experience that the amount it helps cannot be understated.
Full field envy. We dont even have enough room to set up the hoop and the bridge in the same place.
But that is another issue. Thanks for all the input. Bruce |
#10
Our team has never built ourselves a practice robot. We have neither the time or the resources to devote to such an endeavor as building an entire secondary robot. As much as it would help our programming team in being to continue working on a secondary bot while the primary one has already shipped, we just don't have the ability to do such. The best we do is have the programming team work on a robot from a previous year until the one we're building for the current season is complete enough for them to begin actively working on it.
This ws the first year I can remember where our programming team had more than the last 3 days before it had be shipped to actually program though. They had almost a full week! When it comes to making a practice field, we usually build what's necessary. This year we had the baskets and a bridge built and just placed them in the gym for practice. We've never built an entire field before as far having all of the pieces, but what we do build are the essential devices for us to practice with. When it comes close to shipping time we also usually combine with 378 - The Circuit Stompers and their portion of the field to test autonomous modes and competition driving. The idea that we used with The SUITS at FLR where they fed us balls during the Hybrid mode as we shot them was actually first devised at the Kenan Center with 378 a couple of days before shipping. I was quite ecstatic to see the idea come to light, even if it was with another team. |
