Go to Post >wears zebra pants >calls people weird - PayneTrain [more]
Unread 04-05-2012, 19:40
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
2012 KOP Wheels failing.
We switched our robot to the 2012 kit of part wheels and after driving around a bit we had this issue:
http://24.media.tumblr.com/tumblr_m1...s4zo1_1280.jpg
The plastic around the bearing failed and the bearing came loose on the shaft. This was the middle wheel on the standard kit frame, at first we just thought it was a fluke however recently another wheel failed the same way.
So has anyone had this issue? We were thinking about filling the gaps around the bearing with epoxy so they hold up better.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 04-05-2012, 19:52
Re: 2012 KOP Wheels failing.
We had a similar issue with one of our direct driven wheels. The area that the hub was attached to was stripped of material and the threads of the bolt pattern were stripped. For us, I don't think it was due to the product though, we caught the edge of a bridge while driving off of it and I think that's what caught the wheel and sort of pulled it apart from the hub.
Unread 04-05-2012, 19:56
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
We never really subjected these wheels to an excessive large load, no bump just general driving and turning yet it still did this.
Unread 04-05-2012, 20:12
Billfred's Avatar
Billfred Billfred is offline
We haven't noticed any issues through three events--no bump driving, but a little bit of bridge fun.
Unread 04-05-2012, 20:29
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Our team had several of our KOP wheels fail this year. Unfortunately it was because of loctite! We switched them for IFI and Plactions in week 5.
I have seen several KOP wheels fail around the bearing like the one in your picture. This year I thought we would give them a try as the wheels had a nice grip to them but going over the bump was going to be too much for them.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 04-05-2012, 20:38
Eaglesdrb's Avatar
Eaglesdrb Eaglesdrb is offline
FRC #2073 (EagleForce)
Team Role: Leadership
Eaglesdrb is an unknown quantity at this point
We went through two events without any problems with these wheels. However while we did do regular bridge work we did not go over the bump at all and I suspect that might be where these wheels aren't up to the task.
It is all skill and mostly luck.
Allons-y!
Invention is 93% Inspiration, 6% Electricity, 4% Evaporation, 2% Butterscotch Ripple
2010 - Finance Lead
2011 - Vice President / CADD
2012 - President / CADD
Unread 04-05-2012, 21:47
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
We have had the same thing happen to our plaction sheels. The plastic around the hubs broke and so this year we just used colsons and never had those problems.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 04-05-2012, 23:01
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
For the record no loctite was anywhere near the wheel.
Seeing this is an somewhat common issue we will probably fill the area around the bearing with some epoxy to help it hold up.
Unread 04-05-2012, 23:33
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
I saw a few of these that were broken at Championships.
You said that the first one that broke was one of the middle wheels. What wheel was the second one that broke? Do you remember?
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
Unread 04-05-2012, 23:34
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
We broke one of the middle wheels, switched it then broke the other side middle wheel a week or so later.
