Go to Post I know my grandmother would call me a bully for that. And she didn't raise a bully. - Libby K [more]
Unread 04-05-2012, 22:09
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Motors for harvester
After the season has finish our team wants to make some changes to our robot. We were using a cim on our harvester but want to try out a new way to power it. So we wondering if any team can let us know how they power their harvester like what motor, gear ratio any information is helpful. Thanks.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 04-05-2012, 22:13
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: Motors for harvester
We used an Andymark Gearmotor dircetly driven to our rollers. We found that it was a bit slow though, so we would reccomend a Banebots RS550 with a 26:1 gearbox.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 04-05-2012, 22:14
AKA: Rudy
FRC #5572 (Rosbots)
we have some rs550 with 16:1 gear ratio do you think that will work.
[size="1"]
Unread 04-05-2012, 22:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We used a AM PG71 gearbox with a Banebot 550.
Unread 04-05-2012, 22:28
AKA: Rudy
FRC #5572 (Rosbots)
Did you have to modify anything to put the banebot motor on the gearbox.
[size="1"]
Unread 04-05-2012, 22:34
Billfred's Avatar
Billfred Billfred is offline
Our intake roller and ball elevator were driven together, all by a BaneBots 550 through a 16:1 gearbox and a short chain run. The bottom roller was 2" originally; we did add tape between the grooves to build up their depth, so the effective diameter may have been bigger.
Unread 04-05-2012, 22:40
AKA: Rudy
FRC #5572 (Rosbots)
Was it fast or medium type speed our rollers are 2" with the roughtop tread between the polycord
[size="1"]
Unread 04-05-2012, 22:41
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Are initial fast-sucker stage was a 550 with a 16:1 and it worked perfectly with a 1.5 inch pvc roller direct driven.
Our vertical stage was a 550 with a 64:1 directly driven.
Unread 04-05-2012, 22:44
Billfred's Avatar
For lack of a proper measurement: Fast enough. We had to stop our elevator between shots for our shooter wheel to get back to speed.
Unread 04-05-2012, 22:51
AKA: Rudy
FRC #5572 (Rosbots)
Did you chain it or direct drive it. If chained did you run a 1:1 gear ratio
[size="1"]
Unread 04-05-2012, 22:53
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
What's more important than the gear ratio is the linear speed of the contact point. That's the end all comparison really.
Unread 04-05-2012, 22:58
AKA: Rudy
FRC #5572 (Rosbots)
How can we get the best linear speed. Whats the best ball squeeze. We have a 2 inch squeeze although it work well for us we could never hold more then 2 balls because it would jam. Any suggest.
[size="1"]
dudefise dudefise is offline
FRC #2637 (Panthers)
Rookie Year: 2011
dudefise is an unknown quantity at this point
we used a 16:1 Banebots RS775 in our latest version roller that worked extremely well.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 04-05-2012, 22:59
IndySam's Avatar
AndyMark sells a spacer to adapt the motor or you can shorten the output shaft. The spacer is easier. They also sell the gear you need.
  #15   Spotlight this post!
Unread 04-05-2012, 23:01
AKA: Rudy
FRC #5572 (Rosbots)
Thanks we are trying different options to see what gives us the best result. Thank you for the information. I'll pass it on to our build team.
[size="1"]
