| View Poll Results: Which Drivetrain | |||
| 4 Wheel Tank |
47 | 19.42% |
| 6 Wheel Tank |
92 | 38.02% |
| 8 Wheel Tank |
55 | 22.73% |
| 10 Wheel Tank |
3 | 1.24% |
| Mecanum |
19 | 7.85% |
| Swerve |
9 | 3.72% |
| Omni Drive |
2 | 0.83% |
| Other (specify) |
15 | 6.20% |
| Voters: 242. You may not vote on this poll | |||
Re: 2012 drivetrain
48/3193 ran with a 6WD with 8" AndyMark pneumatics (work flawlessly - great product - now offer a 6" version!), no center drop, angled frame with riveted delrin skids.
We easily cross the barrier and possess good maneuverability in both high and low gear. The lack of a center drop permits more stable shooting with no rock. |
Re: 2012 drivetrain
Re: 2012 drivetrain
They most likely de-inflated the front/back pairs of tires a bit so they turn easier, and can get over the bump easier.
Re: 2012 drivetrain
No. Our driver had no issues slinging the bot around. The distance between our front and back tire contact points is 24". Distance between contact points left/right is about 25". We used a West Coast style setup, so that helped us widen the wheel gap.
We also did very slightly lower the pressure of the front and rear tires relative to the center, which we kept near max pressure. There is no noticeable rock on the robot at all. Here is a link to a pic of the underside of 48's robot: https://docs.google.com/open?id=0B5w...3RiTkV6SmlyVXc Last edited by Travis Hoffman : 08-05-2012 at 12:08. |
Re: 2012 drivetrain
6wd long, with supershifters, and a wedge integrated into the frame. If we were going to do it again, I would have gone with 8wd, smaller wheels, and drop down wheels, just so we could get over the barrier slightly quicker. It still wouldn't have made much of a difference, a couple of seconds per match at most.
Re: 2012 drivetrain
We ran 4 8" plaction wheels with toughboxes. For another game where we drive into a steel bar like the bump we might look at different wheels, though two regional events and the championship with just one broken wheel the way we abused them isn't that bad.
We are planning to build a prototype geared drivetrain this fall, much like 25s, because the chain is what gave us the most trouble. Wetzel |
Re: 2012 drivetrain
Wide brecoflex tank treads.
Re: 2012 drivetrain
Wide base, 6-wheel tank. AM roughtop plaction center, omni-wheel corners, back 4 wheels powered. CimPLE boxes, 2 CIMs per side.
Re: 2012 drivetrain
Swerve baby swerve.
#10
Re: 2012 drivetrain
Just curious - Why not power all 6 wheels?
#11
Re: 2012 drivetrain
2815 used a kitbot-derived 6WD--kit wheels and all. Our frame was a hair low for the bump, but I think that was okay in the end due to our CG. If I were doing it again, I'd be more conscious of figuring out the bump.
#12
Re: 2012 drivetrain
We used a 4 wheel mecanum drive train, which was perfect with our 4 sided pick-up system. We could get over the bumb easily with skid plates, we could balance just fine, but I really wish we would have made a wide bot.
#13
Re: 2012 drivetrain
Tank treads.
even though no one on the team had done it before they worked very well even though it took more time then i wanted to spend on the drive train to get them working( week 3 and still didn't have it completed) and took time away from testing our shooter. I would defiantly use them again. even with only two CIMs we couldn't be pushed around. even on the bridge the traction kept the robot from sliding down. |
#14
Re: 2012 drivetrain
We used a 6wd WCD drivetrain, however, the center wheels were mounted on pneumatic cylinders so we could retract them to go over the bump. Overall, it didn't work that well since the middle wheels were not powered.
you never learn anything without trying. Kelly |
#15
Re: 2012 drivetrain
The drivetrain is a 6WD using the AndyMark 8" pneumatic wheels (long configuration). |
