Go to Post What makes a team great is not what they do during the 6 weeks, but what they do the rest of the year. - davidthefat [more]
View Poll Results: Which Drivetrain
4 Wheel Tank 47 19.42%
6 Wheel Tank 92 38.02%
8 Wheel Tank 55 22.73%
10 Wheel Tank 3 1.24%
Mecanum 19 7.85%
Swerve 9 3.72%
Omni Drive 2 0.83%
Other (specify) 15 6.20%
Voters: 242. You may not vote on this poll
Unread 08-05-2012, 17:14
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 2012 drivetrain
Originally Posted by Tubatroopa View Post
We only did 6 so we could be wide and hang off the bridge.
Originally Posted by Siri View Post
True, It's not important for turning. That doesn't means it has no use. In fact extra wheels can provide many useful benefits, especially in non-flat field years.
I agree with you both. Yet there are only marginal incentives to drop the center wheel(s) in the wide drive configuration, as can be demonstrated by running through the math in the paper. My point isn't about extra wheels, but rather the negligibility of dropping those extra wheels. I also wanted to bring up a pretty good paper showing the math/science behind what people think they saw on the field.
GitHub
Unread 08-05-2012, 18:51
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: 2012 drivetrain
Originally Posted by Taylor Nicholson View Post
Our method is passive. We just angled the front and back edges of drivetrain, and riveted on strips of Teflon along the entire base to slide over the the barrier. This has allowed us to drive full speed into the barrier and get over. On 1114, we like the Dukes of Hazzard method of getting over obstacles.
The drivetrain is a 6WD using the AndyMark 8" pneumatic wheels (long configuration).
It was very smooth looking from what I could tell. I was trying to figure out if that behavior could be replicated with 3.5" wheels and some 3x1 tubing, but it looked like you need something more like 4x1, if they even sell that. I know you guys use sheet metal, but do you know what the height from the bottom to the top of the angled part is, and what angle it's at?
The bump liked to get between our 6" wheels and lift our front really high in the air, and it always behaved differently when crossing. The teflon coated skis are probably helpful, but do you have any insight into what you think is most important? I'm guessing the frame getting close to the ground helps so you slide over, but that's just a guess.
Unread 08-05-2012, 17:42
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
Rookie Year: 2010
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Re: 2012 drivetrain
Originally Posted by Alex.q View Post
... I know 111 tipped up the front of their robot to do this, but I never saw exactly how this was done.
Correct. We had pneumatically operated 'landing gear' - two omniwheels on a plate that would push down and lift the front of the robot up. There were two sensors at the front, one on each side, so that when the front of the robot touched the barrier, the landing gear would retract so that the robot could go over smoothly*.
You can catch a quick glimpse of it in action in our reveal video at the 1 minute mark here
*As smoothly as a 120lb robot on air-filled tires can go.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 08-05-2012, 14:57
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
6 6" colson wheels with a center drop in a wide orientation. I liked how it drove but would have preferred a system which takes it over the bump.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 08-05-2012, 15:09
JesseK's Avatar
FRC #1885 (ILITE)
Re: 2012 drivetrain
There is a very basic paper that explains why a drop-center wheel (or set of wheels) is totally unnecessary for wide-drive robots at or near the max robot base dimensions.
http://www.chiefdelphi.com/media/papers/1443
Orientation is just as critical in these responses as # of wheels. .
4WD Tank, Wide Drive.
GitHub
Unread 08-05-2012, 15:11
45 Alumni
AKA: Peyton Yeung
Team Role: Coach
Re: 2012 drivetrain
45 Technokats
Unread 08-05-2012, 15:28
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: 2012 drivetrain
Long-orientation octocanum.
9:1 reduction p80 CIMs direct driving fixed AndyMark HD 6" mecanum, in turn driving articulated 4" performance wheels with roughtop tread via gates sprockets and belting. The performance wheels were at an additional 5:1 reduction, for a total of 45:1.
We love the drive -- it's robust and (relatively) elegant, fast and maneuverable, has monstrous pushing power, and I love that it's chain-free. We're looking at doing something similar with smaller traction wheels -- perhaps 2" colsons -- in the off-season.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 08-05-2012, 15:34
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: 2012 drivetrain
Wide 6 wheel drive with modified AM shifters. Plenty of speed and power.
We used the KOP wheels in a live axle hex driven setup and were thrilled with their performance, especially on the bridge.
Unread 08-05-2012, 15:35
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: 2012 drivetrain
We went with 4-wheel swerve (fully independent drive and steering). It's a great drivetrain, but you do have to compensate for things like hanging off the bridge/even close to the edge and managing ball control while maintaining workable geometry for the Barrier. Definitely doable (we did, though all our official triple balances have been as the middle robot), but extra axles definitely have their benefit.
Unread 08-05-2012, 18:53
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: 2012 drivetrain
Here's a picture of a prototype of our drivetrain. In this picture, we've got two in-house made drive wheels on each side, each being run by two CIM's. Eight colsons are being driven via polycord to power us over the barrier. In our final design, we're powering the lower four colsons on each side via a chain, and powering the upper four via a polycord linkage to the bottom four colsons. I'll try to get a picture that shows this setup tomorrow. It's actually pretty cool what our build team came up with, especially the tensioners. We ran the chains which power the four lower colsons thru a piece of PVC.
EDIT: You can sort of see the final setup in the lower right hand side of the picture, thru the hole in the side of the aluminum plate.
Name:	FIRST Prototype.jpg
ID:	12741  Click image for larger version
Unread 08-05-2012, 19:02
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Re: 2012 drivetrain
1126 was on Swerve drive. The problems that come with being a team in their first year of Swerve aside, the only major problems were had was not directly related to the Swerve. It was mostly that our robot was top heavy and the weight was poorly distributed (When we tried to drive onto the bridge, we would almost flip ourselves because our back wheels didn't have enough weight to keep the bridge down, so it would start coming up on the middle of our drive system).
That aside, the team is generally very happy with how the swerve turned out, and (apparently, I wasn't there) we were even complimented by 16 for having a swerve as good as we did for our first year!
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
