Go to Post many of the greatest innovation throughout history have come from people who have ignored standard practices and traditional thinking. - jason701802 [more]
Unread 10-05-2012, 16:25
SoyStuff SoyStuff is offline
FRC #1257
SoyStuff is a jewel in the roughSoyStuff is a jewel in the roughSoyStuff is a jewel in the rough
CANJaguar Control C++
We are working with CANJaguar for the first time, and we are sort of lost. We have the motors themselves spinning, but we can't seem to control them as we want to. We're in PercentVBus mode, and we are using the regular old set function (we pass it a value between -1 and 1 using the axes on our gamepad). Instead of moving the motor at the speed that is specified, though, it gradually approaches that speed.
Here is a rough outline of our code, just highlighting stuff relating to the CANJags:
Code:
cjag(12, CANJaguar::kPercentVbus), // This is in the constructor for our drivetrain class
// Settings
cjag.SetPID(0.4, 0.005, 0);
cjag.ConfigEncoderCodesPerRev(200);
cjag.SetSpeedReference(CANJaguar::kSpeedRef_Encoder);
cjag.EnableControl();
// Moving
cjag.Set(gamepad.GetY());
Unread 10-05-2012, 17:11
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: CANJaguar Control C++
This is because you are using a PID controller on them. You are telling it to try to get to a certain value. Try not using the PID controller (try removing the cjag.EnableControl(); line and see if you get the same behavior)
Unread 10-05-2012, 19:30
dudefise dudefise is offline
FRC #2637 (Panthers)
Rookie Year: 2011
dudefise is an unknown quantity at this point
He's right, it's due to the PID control. We also used CAN and C++ on our robot this year, and started with P as 1.0, I as 0.01 and D as 0. It will still loop, but will get to speed much quicker, although it may have significant overshoot until you tune it.
As far as I know, there is no way to control the Jaguars with encoders without a PID loop being involved.
I'm not a programmer so I'm not sure about this, but you might also need to construct the CANJaguar as CANJaguar::kSpeed instead of kPercentVbus.
Hope this helps!
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
Unread 10-05-2012, 19:37
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Also note that the mode you're using uses neither PID nor encoders. You want to use speed control to use them.
It also seems to me, looking through the FIRSTForge documentation, that kPercentVbus is no longer a control mode, and has been renamed to be "kPercentVoltage".
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
