Go to Post Jeez, I love my job! :) - dlavery [more]
Unread 11-05-2012, 13:45
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
Team Role: Leadership
Rookie Year: 2010
cjlane1138 is an unknown quantity at this point
How to configure NI CRIO 9148
Hey,
We were wondering where we can get the software from FRC in order to plugin and configure our robot's CRIO. This project is not connected with FIRST, but I need to have the software in order to program the robot.
We bought the NI9148 from National Instruments.
Thanks
Eagle Engineering 1138
Unread 11-05-2012, 13:53
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: How to configure NI CRIO 9148
All the software you need came in the 2012 Kit of Parts. It's the same software you used to program the FRC robot. Do you not have access to it anymore?
Unread 11-05-2012, 14:02
Team 1138
Rookie Year: 2010
We have the LabView disks and the restoration key and all of the other software. We don't have the FRC CRIO, we have a NI CRIO, and so no FRC software has been preloaded in the CRIO. There is no FIRST seal either on the CRIO, so we don't know what to do.
Thanks!
Unread 11-05-2012, 14:27
Software Architect
Oh! The 9148 isn't a cRIO. It's an expansion chassis that connects to a controlling system over Ethernet. It does have a FPGA, but it has no CPU.
You'll need the NI RIO software. That isn't part of what gets given to FRC teams. Start here.
Unread 11-05-2012, 19:27
Team 1138
Rookie Year: 2010
I have gone through these steps, but I need a way to upload C++ code and run the robot through the DriverStation (or another method that uses some other form of a "DriverStation"). This is my issue. I went through these steps, but I do not know how to continue. I have all of the code ready as if the robot were a FRC robot, but I do not have the CRIO (or whatever it is) configured to it.
Thanks
Unread 11-05-2012, 20:05
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Can you confirm that the product you are using is the NI9148, shown here: http://sine.ni.com/nips/cds/view/p/lang/en/nid/209066
Team 1138
Rookie Year: 2010
Yes, that is the product we bought from NI
Unread 11-05-2012, 20:32
Software Architect
You don't run code on the NI9148. You run code on some other computer that communicates via Ethernet and the "Scan Interface" protocol to the C-series modules installed in the NI9148 chassis. You can program the FPGA in the chassis and run "code" that way, but it's probably not what you want to do.
How did you end up with a NI9148?
Unread 12-05-2012, 10:31
Team 1138
Rookie Year: 2010
Thank you for the info. Now how would I be able to set this up? Will I need a separate netbook that is on the robot so it can be connected to the chassis? Or can I just use my computer. Have you ever done this before?
Thanks
Unread 12-05-2012, 10:34
Team 1138
Rookie Year: 2010
We accidentally bought the NI9148 thinking it was the CRIO we needed. I had thought our electronics lead bought the right one...right up until I tried to configure it for code haha.
Unread 12-05-2012, 11:04
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
You should try contacting NI to see if you can exchange the 9148 for an FRCII. They're generally very helpful with matters like this.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-05-2012, 11:05
Team 1138
Rookie Year: 2010
Thank you. We will contact them.
Unread 12-05-2012, 11:11
Rookie Year: 2000
Make sure they know you are an FRC team, they will will route you to the appropriate people.
