Re: Three joint arm
Re: Three joint arm
Here's a look at out 2 jointed arm. The Shoulder is chain driven by the cim on the top half of the robot and the second stage of the arm is driven by a window motor. The claw was controlled by a pneumatic piston that opens and closes. The metal on the arm was .060 i believe, and had aluminum circle tubing that spanned to each side that we riveted into it. This would be something to look at. Message me if you want some more pictures. You could use this for some ideas.
Re: Three joint arm
My Arm Design Methodology:
1. What orientation is the scoring object in when I pick it up? 2. What orientation is the optimum orientation of the object for scoring? 3. What elevation changes do I need to make to the object? 4. What is the simplest mechanism I can use to accomplish the above orientation and elevation changes? Now, #4 is a bit tricky since "simplest" is somewhat subjective. How do I define "simplest"? My personal concept:
IMHO, multiple jointed arms rarely result from this methodology... -John |
Re: Three joint arm
I put "need" in quotes because of the 2011 1503 machine that seemed to defy common logic on what was needed to be excellent. I would put team 25's "2012 bridge manipulator" in the same category. |
Re: Three joint arm
I know it's not FRC, but I thought of NI's Scorbot ... if your school offers Computer Integrated Manufacturing or something like it, you've likely got one of these in-house.
The joint controlling motors are housed near the shoulder joint; the motor at the hand operates the end effector. This design also turrets. |
Re: Three joint arm
-Nick |
Re: Three joint arm
That's why our 2011 robot had a two-joint arm: reaching the floor and the top peg while fitting within the starting configuration. There were of course other ways to do that -- single-joint arm with an extender or forklift-type mechanism, but I don't know that they were in fact any easier or more elegant than what we came up with. (Some were faster, which mattered far, far too much!
Re: Three joint arm
The driver drove the arm into a hard stop to go to the down position, to pickup he extended the claw out, as soon as he had the tube he released the extension and could rotate the arm up and raise the list to position at the same time without haveing to adjust to rotational joints. The extension had multiple effects, it kept the arm as short as possible so it wouldn't sway bounce or move as far during adjustments, it gave us a quick move to steal tubes if was were going at the same one as an opponent, protected the claw by keeping it inside the robot perimeter most of the time, and allowed us to hang middle row without raising the lift. In my experience the easier it is for the driver to understand the movements the better they drive. 2 rotational joints allow multiple ways to get to the same position and creates many possible combinations. of how to get there. Which violates the very solid design rules that JVN outlined above. |
Re: Three joint arm
Three joints arm is hard to the driver to control. my team had in 2011 1 joint and a telescope which is much simplier and more effective
https://picasaweb.google.com/1136626...48580818847090 https://picasaweb.google.com/1136626...48660390128850 |
#10
Re: Three joint arm
Elaborating on JVN and Ike's point...
If additional joints and DOF are necessary, simplifying their execution is key. Our 2011 arm utilized a rotation "elbow" and a very simple "wrist". The wrist only allowed us to fit inside the starting envelope at the beginning of the match and hold the roller claw parallel to the floor. Small pneumatic cylinder with a 1/4-20 bolt as the pivot point. Super simple, super effective. -Brando |
#11
Re: Three joint arm
Yup, ease of use should always be high on the design priority list. The reason we went with screw drives (in restrospect at least partially a mistake) is because it was easy to make push-button controls for each necessary height -- there was a driver override just in case something went wrong with the encoders, but otherwise all the positions were pre-set and slaved to specific buttons.
#12
Re: Three joint arm
A few people have mentioned surgical tubing to help out the motors. Definitely look into this or maybe air shocks, which we used last year on our arm.
#13
Re: Three joint arm
While air shock look nicer than surgical tubing, the nice thing about surgical tubing is that you can tune it to the right strength. Unless you are trying to do something with a lot of power(ie. lifting your robot off the ground), usually surgical tubing is fine.
#14
Re: Three joint arm
