Go to Post If only all this food for thought happening in this thread could somehow be funneled into solving world hunger... - artdutra04 [more]
Unread 15-05-2012, 21:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: The physics of pushing
Originally Posted by DonRotolo View Post
OK, maybe this will help:
If each wheel gets 20 ft-lbs of torque, and the wheel is 6" in diameter, the force acting on the carpet* is 20 / 0.25 = 80 Lbf. (20 is the torque in ft-lbs, 0.25 is the radius of the wheel in ft, and Lbf is "pounds force" (different from pounds weight)).
*Theoretically. Remove maybe 5% for losses (as suggested above), you get 76 Lbf.
Four wheels, 76 * 4 = 304 pounds of force.
Assumes you don't break traction with the carpet.
Be aware that if you are powering 2 wheels with 1 motor, each wheel gets half the torque. Similarly, if you are powering 3 wheels with 2 motors, each wheel gets 1/3 the torque produced by adding the torques of the 2 motors together (and factoring that torque up by the gear ratio, of course). That's why I worded my post in terms of drive motors instead of wheels.
Unread 22-05-2012, 13:44
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Bardd: note that this would require a wheel tread with a coefficient of friction of around 2.0, much higher that commonly used tread materials. When you finish your calculation you should double-check it with other potentially limiting factors such as traction and component strength.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 23-05-2012, 08:32
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
There is also a lot of good info in this thread on designing for pushing from the power electronics aspect:
http://www.chiefdelphi.com/forums/sh...hlight=40+amps
Just because the motors can provide the power doesn't mean the electronics can provide the power (for very long).
Unread 15-05-2012, 15:16
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Rookie Year: 1997
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Originally Posted by bardd View Post
I'm trying to decide on a good gear ratio for our drive system, but I'm kind of stuck on one thing - I can't figure out how to calculate the force the robot could inflict on another robot while pushing (not momentarily). I alraedy have the torqe of each wheel, I'm just missing the next step.
Would the number of wheels make a difference?
If you'd look at JVN's Mechanical Design Calculator, you can see the effects of gear ratio, # of wheels, # of motors, etc. on the effective pushing power of a robot. It allows for easy "prototyping", as the numbers are as simple to change as the push of a button.
I would defer the mathematical explanation to somebody of more knowledge, but for starters you can look at the formulas that he uses in this spreadsheet. JVN's Design Calculator may be found here:
http://www.chiefdelphi.com/media/papers/2059
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
