Go to Post ... Imagine NOT being able to count on certain things to stay the same from year to year... It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 18-05-2012, 12:44
TeacherWeeks TeacherWeeks is offline
FRC #3706
TeacherWeeks is an unknown quantity at this point
Motor Controller Testing
I was wondering if anyone had devised a good way of testing motor controllers? If so I'd love to know your method, my team has a couple of controllers that are questionable and we need to test them.
Unread 18-05-2012, 16:59
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Motor Controller Testing
What type?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 18-05-2012, 17:40
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
You can build your own test rig. All you need is an old unwanted junker laptop and a couple of motors. (And a battery).
Take the laptop and install FreeDOS on it.
Write a simple app to toggle the RTS pin on the serial port to simulate the desired servo signal (you can code it to simulate both Vic and Jag signals). You can get highly accurate and stable performance because there's no multitasking going on. You can hard-code a test sequence into the app, or you can read the test sequence from a text-file script, or you can have a simple user interface to change the command.
Build a fixture to hold 2 motors with their output shafts connected together. Drive one motor with the motor controller you are testing. Run tests with the leads of the other motor open. Stop the test and connect the leads together and run another test with the leads shorted.
Unread 18-05-2012, 20:04
DonRotolo's Avatar
Back to humble
FRC #0832
You can also attach a motor, a battery, and build this. No computer needed.
Unread 18-05-2012, 21:38
Ether's Avatar
Rookie Year: 1969
That looks like a fun project !
The date of your post is 11/05...
Has anyone has built one of these lately? Where did you get the parts and what was the total cost?
Unread 18-05-2012, 23:25
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Why do you need a dual timer? Most circuit I have seen use a 555.
Unread 19-05-2012, 00:56
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
We have something similar, courtesy of our electrical mentor. Unfortunately, I haven't had the time to become familiar with the circuit itself, so I can't provide many details.
Parts were salvaged from his inventory as a hobbyist; I believe total cost was in the $20 range.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 19-05-2012, 01:53
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Here is ours. We use a y pwm cable to the Jags to test ganged motors. We use this device to test our prototypes, motor burn in and robot builds before the electronics go in. All the parts were from Radio Shack under $50
http://www.youtube.com/watch?v=ibuAAnxgExQ
https://picasaweb.google.com/1045493...18593684294434
http://www.youtube.com/watch?v=t-Tius1e10U
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-05-2012, 04:24
sretter's Avatar
sretter sretter is offline
AKA: Shaked
FRC #2231 (OnyxTronix)
Team Role: Leadership
Rookie Year: 2010
sretter is on a distinguished road
Hi, is there any chance that you/one of your teammates could explain a little about how you built it?
(I've seen it before and got excited, but I'm not exactly sure how to implement one ourselves)
Anyways nice idea!
Unread 19-05-2012, 07:49
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Pololu has several RC servo controllers.
http://www.pololu.com/catalog/category/12
I use one hooked to a lap top to run our motors when the C-rio and the programers are not available. Also can do analog conversions to check sensors. The app that runs on the pc is nice.
Unread 19-05-2012, 14:01
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Jameco has a tutorial about PWM:
http://www.jameco.com/Jameco/workshop/diy/pwm.html
http://www.dprg.org/tutorials/2005-11a/index.html
https://www.jameco.com/webapp/wcs/st...0001_120539_-1
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 19-05-2012, 16:41
sretter's Avatar
AKA: Shaked
Rookie Year: 2010
Awesome thanks!
Unread 20-05-2012, 09:10
DonRotolo's Avatar
Back to humble
FRC #0832
Parts are Radio Shack, cost was about $15 including a nice little case. Can be less fancy if you have a good junkbox.
One timer generates the pulses every x milliseconds, the other varies the output pulse width from 1 to 2 mSec. If you try to do both with a single timer you end up varying a parameter you don't want to vary. Plus, a 556 is really no more expensive than a 555...
Unread 20-05-2012, 10:13
FRC #1640
Remember, any device a team makes or buys must be able to generate pulses beyond the 1 to 2 ms pulses that are the hobby standard for servos. The jag has an extended range I believe is .8 to 2.2 ms for full speed. 1 to 2 ms for a victor.
Debugging can issues is a whole other can of worms.
