West Coast Drive: Bellypan
Hello,
Can the knowledgeable Chief Delphi community shed some light on what should go into the design of the West Coast Drive Belly Pan? Main points I feel are: 1. What material/ How thin should the material be. 2. What lightening patterns have worked best for your team? How do you achieve this pattern using solidworks? (Would it just be a matter of using the linear pattern?) 3. How do you design the tabs and mounting holes into the bellypan to ensure correct spacing when bolting in the electronics? Any other points of interest that I have excluded would be great. Thanks, Adam Garcia |
Re: West Coast Drive: Bellypan
It all depends on the construction of the frame. in many WCD's the belly pan is made out of diamond cut alum., which contributes to rigidity, which can become a problem especially in thinner or less sturdily constructed sheet metal or 1x1/ c channel frames. in the event that you have a rigid and strong frame that doesn't need the extra support, I suggest going with something as light as possible, such as our material of choice this year, verilite.
to address 2, I would just create something and linear pattern it however you want. don't really know much about 3, we just lay out our electronics, trace them with a dry erase marker, then drill holes accordingly |
Adam,
There are a lot of examples of different bellypan styles on FRC Designs. Check out the link to the Drives page below! FRC Designs Drives: http://www.frc-designs.com/html/drives.html Matt |
Thanks Matt, I will take a look at these CAD Files
We used 1/8" ABS riveted to the bottom of our frame which seemed to work fine. It was a little flexy in the middle, but we added a support and then it was fine.
I believe its 1/16 or 1/8" thick garolite form McMaster. Adam can provide more details. -RC |
Aluminum bellypans are AWESOME, but are a substantial time and resource sink. I recommend any team that isn't already building 5-star robots to focus their time and resources on something other than a pocketed aluminum bellypan. The runtime on a bellypan for a 2d sponsor can cut several gearboxes, etc... They sure are cool though ![]() |
Little tabs at each corner are nice, but I like making a border for the entire component. It's cooler to look at when there's nothing on it. |
#11
Every time the belly pan subject comes up I have the standard reply of "composites". This is the perfect place on the robot to give students some experience with composite construction methods. A team could use G-10/FR4 sheets. I suggest that teams make their own. A piece of 1/4", 4mm or 6mm birch plywood laminated with a layer on both sides of carbon fiber s2 glass or Kevlar makes a wonderful belly pan - electronics board and provides a great learning experience for the students. Once a team can make a flat sheet other forms can be experimented with. This year we used a .06" wall tube of layed up Kevlar for our beater bar. Took tremendous abuse and is extremely light. Put some fiber in your robots diet.
#12
My experience with G10 Garolite was not as favorable. I found it difficult to cut and that it puts a lot of wear on cutting tools, and I'm not particularly fond of the dust from cutting it. The reason we went with 1/8" ABS was so we could tap it, then use Nylon screws and cut the screws flush with the bottom of the robot, for a totally smooth underside. The ABS is a little soft though, and requires care when tapping.
The garolite is nice and strong though, I'll give it that. |
#13
We've used everything fron 6-32 for Victors up through 1/4-20 for the PDB. As long as you are careful while tapping to keep it straight and get it in one shot (use a cordless drill), you do get enough thread engagement to hold, so long as you don't over-torque the fastener.
#15
Does anybody know if a sheet of garolite is heavier or lighter compared to polycarbonate of the same thickness?
