Go to Post We are not here to build robots, or to win a contest, or to travel to cool places or to bring home trophies. we are here to see what a career in engineering and science is like; anything else that happens along the way is frosting on the cake - KenWittlief [more]
  #16   Spotlight this post!
Unread 20-05-2012, 14:13
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: West Coast Drive: Bellypan
Originally Posted by sanddrag View Post
My experience with G10 Garolite was not as favorable. I found it difficult to cut and that it puts a lot of wear on cutting tools, and I'm not particularly fond of the dust from cutting it.
The best tool for cutting G10 and other fiberglass is a Fein tool. Since Fein's patents recently expired, you can now get similar oscillating cutting tools from other manufacturers like Bosch, Ryobi, and Dremel. Home Depot has a nice selection.
The semicircular metal blades with small triangular teeth work best, and won't break skin if you accidentally bump the tool while in operation.
The dust is a very serious concern! Breathing in the dust from cutting fiberglass can cause silicosis. This is another reason to use an oscillating cutter, rather than a rotozip or dremmel tool. The oscillating tool doesn't throw the dust very far (an inch or so for the majority of the dust). Easy to clean up, and not airborne.
-- Len
  #17   Spotlight this post!
Unread 20-05-2012, 15:00
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Rookie Year: 2007
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Originally Posted by Gray Adams View Post
Once you have your pocketing pattern designed and applied in CAD, layout the electronics in an assembly the way you want them in an assembly. "Edit" the bellypan without "Open"ing it. This should cause everything else to become partially transparent and not selectable. Create a sketch on one side of your bellypan, and then go to the "Project Geometry" tool. Now when you mouseover the edges of all the parts in the assembly, they will light up, and selecting them will project that edge onto your sketch. You're essentially tracing all of your electronics. From there, go ahead and draw lines where you want them, close loops so the Inventor sketch doctor doesn't complain, and then extrude your tabs/outlines/whatever you just designed to mount electronics.
Little tabs at each corner are nice, but I like making a border for the entire component. It's cooler to look at when there's nothing on it.
Be mindfull and take care when using this method as you are creating cross part geometry and dependence. This can be no problem at all, but if the referenced part is modified or removed your very likely to encouter difficulties with constraints and missing reference geometry.
I would reccomend a more time consuming, but more stable method in which you do not project geometry and instead insert the tabs and thru holes for mounting in a seperate sketch from the truss pattern. In this sketch either measure or look up the mounting hole patterns and geometry for the hardware you're including and manually set the spacing for your holes with a dimensioned sketch.
  #18   Spotlight this post!
Unread 20-05-2012, 17:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Originally Posted by Michael Blake View Post
Generally, what size nylon screws do you use? And you get enough thread-bite at 1/8"?! THANKS!
We've used everything fron 6-32 for Victors up through 1/4-20 for the PDB. As long as you are careful while tapping to keep it straight and get it in one shot (use a cordless drill), you do get enough thread engagement to hold, so long as you don't over-torque the fastener.
  #19   Spotlight this post!
Unread 20-05-2012, 17:35
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
Does anybody know if a sheet of garolite is heavier or lighter compared to polycarbonate of the same thickness?
  #20   Spotlight this post!
Unread 20-05-2012, 17:51
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
G-10/FR4 is .067 lb/in^3 and polycarbonate is ~.044 lb/in^3.
The garolite is unquestionably far stronger in this application however. Although commonly used as panels by teams, it is a very poor choice for a structural bellypan (some people will disagree on the basis that they've done it and it works, but it's very inefficient for the same strength).
  #21   Spotlight this post!
Unread 20-05-2012, 18:01
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Yeah, cross-part references can get pretty tricky. I put each component (or type of component) in a separate sketch and extrusion feature so that if I change something, it's easier to deal with. You can also break the adaptivity and make it a normal part so you don't need to worry about it.
  #22   Spotlight this post!
Unread 20-05-2012, 18:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Garolite G10: http://www.matweb.com/search/DataShe... d5f85&ckck=1
G10-FR4 may be slightly different because the "FR4" stands for "Fire Retardant" (implying a different chemical composition for the resin), as explained in the notes section of that link.
Polycarbonate: http://www.matweb.com/search/DataShe...5030fc9 84f35
The polycarbonate link is 1 result from a search that returned over 1000 polycarbonate types, so consider it a generic estimate. For example, the "Unreinforced Polycarbonate" result lists a density of up to twice what the generic one lists, but is a range of densities rather than a specific density. Who knows what the polycarbonate from McMaster is
GitHub
  #23   Spotlight this post!
Unread 21-05-2012, 00:31
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
I think you wanted this PC, not PC/ABS or PC/acrylic 'alloys'
  #24   Spotlight this post!
Unread 21-05-2012, 00:55
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Quite true. I would recommend projecting the geometry of the motor controllers, tabs, etc. in a first sketch and extruding. Then, add the lightening pattern to the back side. Sometimes, I like to dimension the pockets/cheese holes/lightening pattern from the projected geometry of the motor controllers. This way, if you change the arrangement of the electronic components, the mounting holes will not suddenly disappear into one of your lightening holes.
However you decide to do it, I would highly recommend keeping any mounting holes and lightening holes as different features, with the lightening holes farther down the tree.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
  #25   Spotlight this post!
Unread 21-05-2012, 08:22
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
I suggested birch ply as the core material for several reasons. It's cheap, available and easy to use. We do not do west coast drives. On some of our robots the belly pan is a structural member and carries significant loads. Foam core has point impact issues. There are many options for core materials. I suggest a team start with plywood and then move on to more advanced composite methods. This year our beater bar was made of a round tube of kevlar cloth and epoxy. Very light and very strong. There are many places on the bot for team made and purchased composites. I feel the most important thing is to expose students to their use.
  #26   Spotlight this post!
Unread 21-05-2012, 09:12
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
We have done a 254 style bellypan the past couple seasons. Aluminum or not, we like our bellypans to be cut without a bunch of manual operations like laying out the electronics, drilling the holes, etc. This would lead us to some sort of router/waterjet method of fabrication. Since we're already using waterjet, it makes sense to just go for the aluminum version.
We layout all the electronics in CAD, and place the mounting holes into the CAD for the bellypan. If you are designing in SolidWorks, the "Vent" tool is your best friend in the world. It saves a lot of modeling time, and is quite powerful for this type of operation.
We get to anodize our bellypan with the rest of our parts too, so it looks extra cool.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
  #27   Spotlight this post!
Unread 21-05-2012, 21:23
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
For the record, credit for the waterjet bellypan should go to 233 not 254. In 2009, Mike D convinced us to give it a try and we haven't looked back since.
  #28   Spotlight this post!
Unread 21-05-2012, 21:36
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Could you please explain why 254 uses a bellypan? Why haven't you looked back and what did you do before 2009?
Thanks,
Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
  #29   Spotlight this post!
Unread 21-05-2012, 22:14
NickE's Avatar
_
In 2004-2005, we had a ~1/2" sheet of plywood.
In 2006-2008, we had a 1/4" sheet of ABS. It was nice to be able to physically lay out all of the components and just drill/tap holes wherever for mounting & zipties.
The bellypan is of comparable (or less) weight to our previous solutions and acts as a structural member of the frame, stiffening it substantially. Furthermore, when the frame tubes are riveted to it, it acts as a welding jig and holds the frame tubes nice and square. It helps make the competition and practice bots closer to identical. Although it does look good , it is really just a luxury and I wouldn't say having the waterjet baseplate has improved our on-field performance or made our wiring any nicer.
Also to keep in mind, cutting a baseplate like this has some disadvantages including requiring significant advance planning and a solid grasp on how the wires and hoses connect all of the components. Furthermore, it takes a ton of waterjet time and we're lucky to have the resources to be able to do this. For 90% of the teams in FIRST, a waterjet baseplate is probably not worth it. There are better ways to use design and machining resources to move your robot into that top 10%. However, for teams who have the time and the resources, it is a nice thing to be able to do.
  #30   Spotlight this post!
Unread 21-05-2012, 23:14
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
Interesting, our analysis suggests that it is actually quite inefficient as a structural member. What you are saying pretty much corresponds with where my head was on bellypans: they are nice, but not mandatory. At least in our sheet metal construction, another well placed cross-member is probably a more effective use of weight. I do really like the use of the bellypan as a welding jig though, that makes perfect sense for a stick construction method.
Thanks for the info!
Regards, Bryan
