Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Unread 10-11-2001, 12:57
Tech Fusion Tech Fusion is offline
#0279 (Tech Fusion)
Tech Fusion is an unknown quantity at this point
Question Heat sinks
We have three questions:
Q1: Can we use aluminum heat sinks, and if so do we have to make them or can we buy them already made?
Q2: We cannot use direct drive, so what kind of drive is not illegal?
Q3: Before the seeding matches/tournament matches how much time do we have to power up our robot?
Unread 11-11-2001, 07:39
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Heat sinks like all other parts MUST comply with the rules for building the robot. a) Do not modify the NO MOD parts b) parts must be from the kit of parts provided or made without precision machining or welding from the additional hardware list. If the heat sinks you are asking about are not on the list (I do not recall them being on the list) than the answer is NO to buying them, and if you make them be very careful how you attach them.
I think you answered your own question!
In the Rule book there is a time table scenario that we use - this process has been used the past couple of years and works well in keeping the event schedule "on time". All new or rookie teams should pay attention to this process as written. Generally after one match the people on the teams setting up their robots understand the sequence and things go quite smoothly.
Unread 11-11-2001, 19:57
#0279 (Tech Fusion)
Thanks for the help.
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
'IT' info... archiver 2001 19 24-06-2002 01:58
heat sinks archiver 2000 1 23-06-2002 22:45
New IT info? Mike Soukup Dean Kamen's Inventions 10 08-12-2001 23:03
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
