Go to Post knowing 'my breath stinks' has helped me far more than any thanks and praise I've ever received.. - DonRotolo [more]
Unread 22-05-2012, 13:08
RoastBeefer RoastBeefer is offline
FRC #3055
RoastBeefer is an unknown quantity at this point
Java button help
Hello, we are brand new to programming in Java this year. We are following the cookbook from firstforge. We were able to move the robot using a joystick but cannot figure out how to use a button to enable a motor. We created a subsystem called shooter then a command called ShootBall. We get an error in out code and can't figure out why. Our code is in the attachment.
Here is shooter:
Code:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package edu.wpi.first.wpilibj.templates.subsystems;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.buttons.Button;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.templates.commands.ShootBall;
 * @author Developer
public class Shooter extends Subsystem {
    Jaguar leftMotor, rightMotor;
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    public void initDefaultCommand() {
        setDefaultCommand(new ShootBall());
        // Set the default command for a subsystem here.
        //setDefaultCommand(new MySpecialCommand());
    public Shooter(){
        leftMotor = new Jaguar(3);
        rightMotor = new Jaguar(4);
        leftMotor.setSafetyEnabled(false);
        rightMotor.setSafetyEnabled(false);
    public void ShootBall(Button a){
        a.whileHeld(new ShootBall());
And here is ShootBall:
Code:
package edu.wpi.first.wpilibj.templates.commands;
 * @author Developer
public class ShootBall extends CommandBase {
    public ShootBall() {
        requires(shooter);
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
    // Called just before this Command runs the first time
    protected void initialize() {
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        shooter.ShootBall(oi.getButton());
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return false;
    // Called once after isFinished returns true
    protected void end() {
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
Here is OI in case you need it:
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.buttons.JoystickButton;
 * This class is the glue that binds the controls on the physical operator
 * interface to the commands and command groups that allow control of the robot.
public class OI {
    public static final int JOYSTICK_PORT = 1;
    private Joystick stick;
    private Button a;
    public OI(){
        stick = new Joystick(JOYSTICK_PORT);
        a = new JoystickButton(stick, 1);
    public Joystick getJoystick(){
        return stick;
    public Button getButton(){
        return a;
    //// CREATING BUTTONS
    // One type of button is a joystick button which is any button on a joystick.
    // You create one by telling it which joystick it's on and which button
    // number it is.
    // Joystick stick = new Joystick(port);
    // Button button = new JoystickButton(stick, buttonNumber);
    // Another type of button you can create is a DigitalIOButton, which is
    // a button or switch hooked up to the cypress module. These are useful if
    // you want to build a customized operator interface.
    // Button button = new DigitalIOButton(1);
    // There are a few additional built in buttons you can use. Additionally,
    // by subclassing Button you can create custom triggers and bind those to
    // commands the same as any other Button.
    //// TRIGGERING COMMANDS WITH BUTTONS
    // Once you have a button, it's trivial to bind it to a button in one of
    // three ways:
    // Start the command when the button is pressed and let it run the command
    // until it is finished as determined by it's isFinished method.
    // button.whenPressed(new ExampleCommand());
    // Run the command while the button is being held down and interrupt it once
    // the button is released.
    // button.whileHeld(new ExampleCommand());
    // Start the command when the button is released  and let it run the command
    // button.whenReleased(new ExampleCommand());
Sorry if we posted things wrong. We didn't know how to attach code
