| Thread Tools |
Rating:
Display Modes |
PID encoders vs hall sensors
Ive been reading about pid and it says for gearbox control you can either use encoders or hall sensors (gear tooth sensor)
Re: PID encoders vs hall sensors
The advantage about a quad encoder is you can know which direction your gear box is going. A hall effect sensor can work quite well, but it will not give you direction. The encoder will also give more pulses per revolution.
For speed, i am not sure that it matters. For position a quad encoder would be better |
The first Gear Tooth Sensor supplied in the Kit of Parts actually did give direction information. It provided a single output pulse for each gear tooth passing by, with a short pulse width indicating one direction and a longer pulse width indicating the other.
An encoder (in FRC parlance) is a sensor that detects rotation. The sensor technology can be resistive (potentiometer), optical, or magnetic (Hall sensor) to name a few.
Most encoders in FRC deliver pulses, so many pulses per revolution (except potentiometers). Using two carefully-placed sensors can deliver both speed and direction information. The choice of the sensor technology to use depends on the application: Optical sensors can operate far faster, Hall sensors are great in sensing things magnetic, meaning your sensor wheel can be an existing gear or sprocket. In most cases, size/weight/cost/performance are the general tradeoffs. The word Encoder has many definitions; here we are referring specifically to a rotational encoder. |
