Go to Post but look at the bright side, you will now be able to size 1/4-20 nuts with your forearm and i doubt there are many people who can say that :p - Greg Needel [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:23
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Dashboard - Actual use?
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 3/14/2000 11:48 AM MST
Yet another post from the 'Dashboard Guy'...
Ever since the dashboard port was announced, there has been a LOT of buzz around the teams as to the possibility for advanced feedback. However, after seeing the field at Great Lakes, I only saw two teams actually using a laptop on the field, with at least one more on the way being worked on in the pits. I was just wondering how many people are actually planning to use it? Also, if you are using my decoder, please mention that in your post too. =) Thanks!
Nate
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Re: Dashboard - Actual use?
Posted by Justin Ridley.
Engineer on team #221, MI Roboworks, from Michigan Technological University.
Posted on 3/14/2000 1:35 PM MST
In Reply to: Dashboard - Actual use? posted by Nate Smith on 3/14/2000 11:48 AM MST:
We will be using JBoard, a program one of our students made. It's pretty cool.
#0047 (ChiefDelphi)
Posted by Tony K.
Student on team #292, PantherTech, from Western High School and DaimlerChrysler.
Posted on 3/18/2000 4:12 PM MST
I wrote PortSnoop, but since we can't afford a powerful enough laptop, we can't use it. And I don't think we could use it on the field and be in good relations with our coach at the same time .
But I got away with it by using Pbasic's Debug...
Tony
#0047 (ChiefDelphi)
Posted on 3/18/2000 7:35 PM MST
In Reply to: Re: Dashboard - Actual use? posted by Tony K on 3/18/2000 4:12 PM MST:
: I wrote PortSnoop, but since we can't afford a powerful enough laptop, we can't use it. And I don't think we could use it on the field and be in good relations with our coach at the same time .
You sure about that Tony? I've run the demo program with the decoder on machines as low as a 133 Pentium with 16MB RAM...
: But I got away with it by using Pbasic's Debug...
While on the field? How are you pulling that off?
Nate
[IMG] code is Off
miroboworks dashboard program? archiver 2000 3 23-06-2002 23:04
Dashboard Decoder Release Version 1.0 Now Available! archiver 2000 1 23-06-2002 22:50
Dashboard Protocol Library archiver 2000 9 23-06-2002 22:24
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Dashboard Viewer Khalicl13 Technical Discussion 8 15-06-2001 23:36
