Go to Post Not sure if its fair to call this or not yet. Back a group of dedicated teenagers far enough into a corner, and they're gonna find a way out. - Racer26 [more]
Unread 05-06-2012, 17:23
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
Rookie Year: 2011
2185Bilal will become famous soon enough
Post Code and Deployment Help
Hello with the help of Youtube and CD I was finally able to make my first java program for the robot.
Here it is:
The main class:
Code:
// ***************** THIS CODE WAS WRITTEN BY BILAL MAJEED ***************** //
package bilal.robotics.code;
// ***************** TO BE USED COMPONENTS ***************** //
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Timer;
public class Team2185Main extends IterativeRobot {
    Jaguar leftMotor1 = new Jaguar(1);  // define the 1st left motor
    Jaguar leftMotor2 = new Jaguar(2);  // define the 2nd left motor
    Jaguar rightMotor1 = new Jaguar(3); // define the 1st right motor
    Jaguar rightMotor2 = new Jaguar(4); // define the 2nd right motor
    RobotDrive drive = new RobotDrive (leftMotor1, leftMotor2, rightMotor1, rightMotor2);   // define the robot drive system
    Joystick controller = new Joystick(1);  // define the joystick as controller
    final int buttonA = 1;                  // define button 1 as buttonA
    Shooter shooter;
// ***************** INITIALIZATION CODE ***************** //
    public void robotInit()
        shooter = new Shooter(); // call the shooter class
// ***************** AUTONOMOUS METHODS ***************** //
    public void autonomousInit()
        for(int i=0; i<4; i++){
            drive.drive(0.5,0.0);    // drive forward at 1/2 speed
            Timer.delay(2.0);        // wait 2 sec
            drive.drive(0.0, 0.75);  // drive with 0% speed and 75% turn
            Timer.delay(0.75);       // wait for the 90 degree turn to complete
        drive.drive(0.0,0.0);
    public void autonomousPeriodic()
    public void autonomousContinuous()
// ***************** TELOP METHODS ***************** //
    public void teleopInit()
       while(isOperatorControl() && isEnabled())
            drive.tankDrive(controller, 2, controller, 5);  // drive the robot according to joystick
            if (controller.getRawButton(buttonA))   // if button 1 is pressed on the controller
            {                                       // then make the robot drive forward
                leftMotor1.set(1);
                leftMotor2.set(1);
                rightMotor1.set(1);
                rightMotor2.set(1);
    public void telopPeriodic()
        shooter.shoot();    // every 20mS call the shooting class
    public void telopContinuous()
// ***************** DISABLED METHODS ***************** //
    public void disabledInit()
    public void disabledPeriodic()
    public void disabledContinuous()
And the shooter Class:
Code:
import edu.wpi.first.wpilibj.Joystick.ButtonType;
public class Shooter
    Jaguar shooter = new Jaguar(5);
    Joystick controller = new Joystick(2);
    public Shooter()
    public void shoot(){
        if(controller.getRawButton(buttonA)) {
            shooter.set(controller.getRawAxis(2));
So please tell me anything i did wrong, or a better way to do it.
Thanks
Also how would i deploy this code on to the robot.
Thanks
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
