Go to Post If mentors don't respect the students' desire to learn and take an active role in the construction, they're missing the point of FIRST. If students refuse to accept the knowledge and experience of the mentors, that's not independence - it's arrogance. - DB213parent [more]
Unread 24-06-2012, 23:13
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: 2012 FRC Team 1717 Uncut
One more thing...the swerve modules seem to rotate a lot as you stop and prepare to shoot. Is this part of re-zeroing the gyro for each shot, or some other reason?
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 25-06-2012, 01:39
jakemochas jakemochas is offline
Programmer
FRC #1717 (The D'Penguineers)
Team Role: Student
Rookie Year: 2012
jakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud of
Hi everyone! Our answer to the gear cutting question has been approved and can be seen above at post #65. The post is above because it was posted on the 18th, but it didn’t show up until today. We are working hard to post all of our other answers as well! Thank you for your patience.
Originally Posted by dcarr View Post
I had a few questions regarding encoders:
We're working on our drivetrain over the summer. The past two years we have used CAN with our Jaguars, connected to a 2Can, but it has been riddled with problems. So we are switching to PWM which I know you guys use and plugging the encoders into the sidecar. Since each encoder can take 2 I/O ports, how did you manage that-did you fill one up? (if so, did you use more than one sidecar?) How did your sensor arrangement work, did you use many others besides the encoders and the gyro?
Thanks for taking the time to answer these questions, it is greatly appreciated!
In order to PWM our 14 motor controllers and have enough I/O for the encoders, we did use two digital sidecars. As a result of the new motor allowance this year, it was the first time we used two digital sidecars.
We had many sensors on our robot that were wired to the analog and digital slots of the cRIO. For our swerve drive, we used two types of sensors: we used magnetic encoders on the analog board for wheel orientation and optical encoders for the wheel drive. Also, the gyro was attached to an analog port.
For the shooter, we used a magnetic encoder attached to the analog breakout to detect the platform position. For the hood angle, we used a multi-turn potentiometer on the analog breakout. To detect flywheel speed, we read from a light sensor that was attached to the digital sidecar I/O.
The rotation of the wheels when we prepare to shoot is mostly from re-zeroing, but some of the turning is from fine adjustments the driver makes while lining up for the shot.
Unread 25-06-2012, 10:42
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
Rookie Year: 2010
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
When you say light sensor do you mean optical encoder?
Unread 25-06-2012, 11:41
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
He may just mean a light sensor (like a Banner sensor, or a 2011 KOP line sensor) being used as a digital tachometer with a piece of reflective tape or a photogate. Nothing to "encode" (in a quadrature sense), since your wheel generally isn't changing the direction that it rotates.
Unread 25-06-2012, 11:53
JamesTerm's Avatar
Terminator
AKA: James Killian
Rookie Year: 2010
Thanks Jared, that is what I was thinking as well... I'd love to see how well this compares against an encoder (either kind)... as of now, I am still frustrated with encoders with these high of speeds.
