Go to Post [In FIRST]...Arab and Israeli students speak on the same level, because they are alliance partners. - Tottanka [more]
Unread 06-12-2012, 11:20 PM
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Mentor
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2012
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Thumbs down Java Servo Issue
This all seems so simple... but we've been unsuccessful getting a servo working in our Java code. We are using a Hitec HS-475HB servo attached to a PWM port on the digital sidecar. We've tripled checked PWM port number and it is correct. I don't have the code with me but here is basically what we are doing:
1) Created a new subsystem class for the servo
2) In the constructor we instance a Servo class using the PWM port as the argument:
m_myServo = new Servo(2);
3) In a method called MoveMyServo() we call
m_myServo.setAngle(20); // actually we increment the previous value by 20
4) We've tried called setPostion() and set() with no joy but after looking through Servo class all these methods eventually call setPosition() with a value from 0-1.
5) Put print statements and stepped through the debugger to verify that the constructor is being called (without errors) and the MoveMyServo() method gets called each time the button is pressed.
In the Servo class it mentions it is set up for a Hitec HS-322HD... does that matter? Are we missing something here?
Unread 06-12-2012, 11:51 PM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Java Servo Issue
Is the power jumper (next to the PWM connector) installed?
Fast, cheap or working - pick any two!
Unread 06-13-2012, 01:57 AM
WizenedEE's Avatar
WizenedEE WizenedEE is offline
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Team Role: Leadership
Rookie Year: 2010
WizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to allWizenedEE is a name known to all
The power jumper seems like it's the most likely error, but you could also try the servo on another pin. One of ours had died (we left a PWM cable hanging off of it and it shorted)
Unread 06-13-2012, 08:17 AM
Mentor
Rookie Year: 2012
That must be it! Will try it out tonight.
Unread 06-13-2012, 11:09 PM
Mentor
Rookie Year: 2012
Jumper solved the issue. Thanks guys!
