Go to Post Never underestimate the power of curious and impatient FIRSTers ;) - kpugh [more]
Unread 18-06-2012, 21:56
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
EE question: convert RS232 voltages to RC servo
Looking for EE's to comment please.
I want to convert a -12V to +12V PWM signal to RC servo voltage levels (0 to +5V), with sufficient current to reliably drive a Victor.
I cannot locate any specs for the Victor's input impedance and required minimum input voltage.
I'm thinking a simple circuit like this will do the job. The questions I have are these:
- Is 1200 ohm a small enough output impedance to reliably drive the Victor's input?
- Is the 2.7MegOhm small enough to allow the 12V input to drive the 2N3904's base?
- Will the transistor operate as desired (i.e. shut off) with a -12V signal at the base, without damaging the transistor?
- Will these resistance and voltage values keep the 2N3904 within a safe operating range ?
