AM Shifter: 2:56:1 spread vs. 4:1 spread
I've been looking into the AM shifter transmissions, but have no idea how to calculate the 2:56:1 or 4:1 into my calculations (using JVN design calc). Can someone explain the two to me, and if possible the gearing that goes on in there? This is probably really simple, but I've spent 3 days trying to figure this out.
![]() Thanks! |
Re: AM Shifter: 2:56:1 spread vs. 4:1 spread
The 4:1 has final reductions of 10.67:1 and 2.67:1. If I remember correctly, the difference comes from flipping a 28:35 to a 35:28, or vice versa. |
Andrew,
The spread is determined by changing the gears inside the transmission. On JVN's calc on the 2 speed section, replace the numbers with the different gear sets available from AM. If your still a little lost, feel free to hit me up via PM/IM. -RC |
Those are the ratios between the high and low gears. The ratios that you would want to put in the calculator are under gearing on the product page.
For the 4:1 spread: Low Gear: 10.67:1 High Gear: 2.67:1 For the 2.56:1 spread: Low Gear: 10.67:1 High Gear: 4.17:1 |
I sorta understand the spread, but the gears are my main problem. I'm looking at this picture (http://www.andymark.com/PhotoDetails...tCode=am-0001), and don't see what gears are used. I see the two gears in the picture, but I don't think those are the only ones.
Code:
AM Shifter AM-0957 Drive PN Driven PN Drive NT Driven NT SET RATIO O'ALL RATIO AM-0018 AM-0024 12 40 3.33 AM-0451 AM-0022 15 48 3.20 10.67 AM-0139 AM-0140 35 28 0.80 2.67 AM Shifter AM-0001 Drive PN Driven PN Drive NT Driven NT SET RATIO O'ALL RATIO AM-0018 AM-0024 12 40 3.33 AM-0451 AM-0022 15 48 3.20 10.67 AM-0025 AM-0023 28 35 1.25 4.17 Last edited by Tom Ore : 21-06-2012 at 05:05. |
2.56:1 Spread
(40/12)*(48/15)=10.667 (40/12)*(35/28)=4.167 2.56:1 Spread 12T input gear (x2 - CIM) 15T small cluster gear (output side) 28T medium cluster gear (motor side) 35T small output gear (motor side) 40T large cluster gear (center of cluster - direct input from 12T) 48T large output gear (output side) 4:1 Spread (40/12)*(48/15)=10.667 (40/12)*(28/35)=2.667 4:1 Spread 12T input gear (x2 - CIM) 15T small cluster gear (output side) 28T small output gear (motor side) 35T medium cluster gear (motor side) 40T large cluster gear (center of cluster - direct input from 12T) 48T large output gear (output side) Last edited by A_Reed : 21-06-2012 at 08:16. |
I must say, that is a beautiful rendering. |
Thanks everyone! I understand it now!
#10
There are two or three other gears that transfer the output of the motor(s) to what I've called the power shaft. They provide a first-stage reduction from the motor speed, but they aren't involved in the shifting. |
#12
I would also caution you to look at your output power vs. speed with the two ratios. The 4:1 has a pretty big power trough between the peak powers. If your system spends a lot of time in this zone it can eat a battery alive.
