Go to Post ask not what your alliance picks can do for you, but what you can do for your alliance picks. - Swan217 [more]
Unread 28-06-2012, 16:59
nydnh01 nydnh01 is offline
AKA: Naresh Hing
FRC #1601 (Quantum Samurai)
Rookie Year: 2011
nydnh01 is an unknown quantity at this point
Arrays with motor control
I am new to using arrays for programming in FRC labview. Can someone post an example of how to use buttons with arrays for controlling a motor. Thanks in advance.
Unread 28-06-2012, 17:31
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Arrays with motor control
Are you sure using arrays is what you need to do? The "use buttons with arrays" sounds like a case of specifying "how" before having a clear idea of "what". Step back a bit and tell us what you're trying to make the robot do, in terms that don't require a particular implementation or even a specific programming language.
