Go to Post Gearboxes and 2x balls and pull up bars, oh my! - Marc P. [more]
Unread 07-07-2012, 22:20
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
Re: Turning LEDs on/off
Originally Posted by flameout View Post
For anyone who reads this thread in the future:
Reversing polarity on a LED will not damage the LED
Only reason I said that is because I actually did make one pop when I wired it backwards.
And like flameout said it won't hurt the sidecar or the LED at that voltage. An LED is a diode so it only lets current through in one direction and also happens to light up.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 07-07-2012, 22:31
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Reversing polarity on a LED will not damage the LED (or the Digital Sidecar, for that matter) -- it will simply not night.
Caution: the above is true only if driving the LED with a source whose open-circuit voltage is less than the reverse voltage which would damage the LED.
A high voltage high impedance source might work fine in the forward direction but damage the LED if polarity is reversed.
