Go to Post ... as teammates we often get too into the craze of competition and forget that this wouldn't happen without so many dedicated people. - miketwalker [more]
Unread 07-07-2012, 18:31
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Turning LEDs on/off
I have an LED wired to the digital side car power and ground pins. I want to be able to turn it on/off programatically, but it always stays on. I am using Labview to open a digital output sand setting it to false, but the LED is always staying on.
I have the jumper on the DSC's port.
What am I ding wrong? Should the LED be wired to the ground and signal pins?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 07-07-2012, 18:36
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Turning LEDs on/off
Wiring to the signal pin sounds like it would work.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 07-07-2012, 19:09
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The power stays on. Only the signal turns on/off. Whether or not the LED will illuminate when you connect it between signal and ground depends on how much current the LED requires to illuminate, and how much current the signal can source. What's the part number of the LED?
Unread 07-07-2012, 21:07
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
I think you are right when you say that you should wire to signal and ground, just don't mix up positive and negative on the LED, they make a nice pop sometimes, you can also run LEDs on spike relays if they are 12 volt
Edit: Also the signal may not carry enough current to power LEDs in which case you should use a spike
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 07-07-2012, 21:35
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
LEDs from SuperBrightLED
Qty | Product / Options | Price/ea |
12 | RL5-G7532: 5mm Green LED | $ 0.54 |
RL5-G7532: Green LED
Resistors from www.MOUSER.com
299-82-RC
299-82-RC
82ohms
Assuming the flat side of the LED is the negative side.
Going to try the ground/signal setup now.... thanks
Unread 07-07-2012, 21:57
Ether's Avatar
Rookie Year: 1969
Why did you select 82 ohm?
Unread 07-07-2012, 23:26
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
I used the calculator linked below to determine the resistor. Forward current was 20mA, source voltage was 5v and the forward voltage was taken from the LED specs.
http://led.linear1.org/1led.wiz
When I switched to the signal tonight, there was no light when I set the DIO to true or false. When the LED is on power and ground, it comes on
Unread 08-07-2012, 00:40
Ether's Avatar
Rookie Year: 1969
Sounds to me like the output impedance of the DIO signal line is too high to provide enough current to light the LED (as mentioned in my earlier post).
Disconnect your LED circuit and put a voltmeter (a cheap $10 one will do) between signal and ground at the DIO output. Flip the DIO true/false and confirm that you are getting 5 volts and zero volts.
Now connect your LED circuit (leaving the voltmeter connected between signal and ground). My guess is that you will no longer see 5 volts. The load from the LED acting on the impedance of the signal source will drop the voltage below that necessary to provide the current to light the LED.
Unread 08-07-2012, 00:48
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
Now connect your LED circuit (leaving the voltmeter connected between signal and ground). My guess is that you will no longer see 5 volts. The impedance of the signal source will drop the voltage below that necessary to provide the current to light the LED.
I'll check as soon as the show is over (the robot is part of the play Something's Afoot). If that is the case, what is the solution?
If I use a spike to control it, I assume I will need a different resistor to handle a 12v input? Or I run 5v throught the spike?
Unread 08-07-2012, 01:00
Ether's Avatar
Rookie Year: 1969
Instead of using the signal as a power source to drive the LED, you could use the signal to control a transistor which switches the DIO power line.
I'll draw a sketch and post it here in a few minutes.
Unread 08-07-2012, 01:08
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
Very cool thanks Ether.
Unread 08-07-2012, 01:19
Ether's Avatar
Rookie Year: 1969
Something like this.
edit: corrected resistor value
Unread 08-07-2012, 03:46
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
When I buy the FET, is there anything specific I need to look for? Probably going to Radio Shack to find one tomorrow. If not available then will probably go to mouser.
Unread 08-07-2012, 15:20
DonRotolo's Avatar
Back to humble
FRC #0832
The DSC Digital I/O does not appear to be able to sink 20 mA.
Ether's transistor switch should work fine. A FET (especially an IFF510) may be overkill, a plain NPN switching transistor will be fine.
All these parts (resistors, 2n2222 or 2n3906 transistors) are available at Radio Shack.
  #15   Spotlight this post!
Unread 07-07-2012, 22:04
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
For anyone who reads this thread in the future:
Reversing polarity on a LED will not damage the LED (or the Digital Sidecar, for that matter) -- it will simply not night. LEDs are diodes. Feeding them too much power, however, can make them pop.
