Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 07-07-2012, 20:48
OliviaG's Avatar
OliviaG OliviaG is offline
No capes
AKA: Olivia Gifford
FRC #1094 (The Channel Cats)
Team Role: Driver
Rookie Year: 2011
OliviaG is an unknown quantity at this point
Send a message via Yahoo to OliviaG
Question Scouting
What kind of Scouting program does your team use? As in what is your method do you use a computer, or paper? and how many students do you have doing the scouting? Ours is 2 people on paper and 1 person sitting on the middle on the computer watching the matches, It works really well.
I'm just curious.
"Not everyone has the chance to do great things - to learn how to build a robot while working alongside some of the greatest mentors you will ever meet, to become one with your team, and learn to be a gracious professional while competing with exceptional teams. It's not every day you meet people who want to change the world. Being inspired, learning, creating, thinking, and doing things to shape the future. THIS IS FIRST." -Me
Unread 07-07-2012, 21:39
hammerhead_399's Avatar
hammerhead_399 hammerhead_399 is offline
Team Manager
AKA: Gabriel Ruiz
FRC #0399 (Eagle Robotics)
Team Role: Driver
Rookie Year: 2007
hammerhead_399 is an unknown quantity at this point
Re: Scouting
Be sure to search CD before you post. There are several threads on this subject.
Our team usually has 7 people scout. 6 for each robot per match, and 1 for input in a spreadsheet scouting database. Our spreadsheet was used to keep track of shots made in each hoop, shot percentage, points scored, bridge/barrier traversals, and balances. It helped a lot when it came to deciding between 2 fairly equal teams.
Unread 07-07-2012, 22:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Scouting
It's summer so I'll entertain the common and duplicate thread on the subject.
Our setup was rather elaborate. We used a Google Docs spreadsheet and form to populate it with 7 laptops and 7 students. The Google Docs spreadsheet was rather fancy with lookups and pivot tables. We had six scouts (one for each robot) and a head scout for data checking and review and as a stand-in if someone had to leave. We used a Clear 4G WiMax USB adapter into a Cradlepoint router into a network switch and ran a wired network to the 7 laptops. We also had a cameraman with a tripod taking full-field video of every match and encoding and uploading to Youtube on the fly from the stands. Then down in the pits, we had another Clear 4G WiMax adapter, Cradlepoint router, and network switch with a computer setup with a 24" widescreen monitor so we could jump on Youtube and watch past matches or jump on Google docs and look up scouting data. It all worked great, but it's not the simplest setup, and it does incur some cost. One interesting note is we went through over 20 Gigs of bandwidth between the two Clear devices over the three day period.
Unread 08-07-2012, 18:07
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Re: Scouting
Olivia,
Your system sounds similar to ours. As you found out, it is still possible to get good information with 3 scouts.
We use a 3 computer system - one red alliance, one blue alliance, and one master scout. The alliance scouts collect basic scoring statistics while the master scout comments on a team's playing tendancies.
We have used paper in the past, but found that we can focus on collecting data than having a master scout shuffle and file paper.
We are going to publish a white paper with more details on our system shortly.
Unread 08-07-2012, 21:24
OliviaG's Avatar
No capes
AKA: Olivia Gifford
Team Role: Driver
Rookie Year: 2011
Smile Re: Scouting
Originally Posted by D.Allred View Post
Olivia,
Yes it is very similar.
We used paper last year, but it was too much we had to carry around, so now we have 2 students watching each alliance,
We use paper but we cover it with a clear plastic sheet and use dry erase markers, so the person in the middle using the computer just looks down at their clipboard and puts it all into the program, and then they just erase the writing on the clipboard, and we can re-use the paper. Its pretty accurate, and its easy to set up.
Unread 09-07-2012, 00:32
Jibsy's Avatar
Jibsy Jibsy is offline
Mentor - 3756, 4525
AKA: Jared Baribeau
FRC #3756 (Ramferno)
Rookie Year: 2011
Jibsy will become famous soon enoughJibsy will become famous soon enough
Re: Scouting
This season we used a fairly simple paper system. It consisted of one sheet per team (per competition), with enough rows for all of the matches, and all of the stats were tracked with tallys in the columns.
It was very primitive, but very easy to develop. Myself and a teammate are currently finishing up our own software that will be used for live scouting on laptops. Up to 3 teams can be scouted on each computer at a time. This saves the data into the database, which can later be imported to a master database on one of the computers.
If having multiple laptops is an issue, the stats can be marked down on paper (such as the way Olivia mentioned) and then entered after the match.
The stats can then be viewed in a master table or in each team's individual profile (which contains the team's stats, a robot photo, pit scouting information, etc.)
The plan is to release the finished and tested software to the community for criticism in the off season and then a 2013 version some time after kickoff next year.
As for numbers, we typically have one student watching each robot, but that's probably overkill in most scenarios.
Unread 09-07-2012, 08:11
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
Re: Scouting
On Team 33, we have a lot of active members engaged in scouting. We typically have 6 scouts (1 for each robot), and 1 master scout organizing assignments. We scout each robot to a sheet that has multiple cells. An example of the 2012 sheet is here. We often have specialty roles as well like human player scouting in 2009, Minibot scouting in 2011, and pit scouting.
We also typically have a "master scout" that does match scouting. Match scouting is where you scout th 5 robots who will be in your match before the match starts. We like to use the previous match data, though first match of the day relies on pit scouting, and after 3-4 matches, you can use "data trends" more reliably though this data is still pretty spotty. This master scout reviews what they think the opponents will likely do, and what they are capable of. They also cover what your partners are likely capable of. Lastly they develop a general match strategy to review with the coach. Ultimately, strategy is up to the coach, but it is the scouts responsibility to let them know what to expect, and to give a recommendation.
I have also put together a "generic" scouting booklet located here. There are lots of issues with subjective data, but it is usually better than no data. This booklet gives the user some nice options to try to organize observations about a particular team, and to ensure you get some data on every team.
Remeber, the msot important rules to scouting:
#1 Know thy customer: A bunch of useless data is useless. Collect meaningful data for its intended use (match strategy, pick list, future robot improvements, a white paper on the correlation of # of wheels with success...).
#2 Data in a computer with a dead battery is essentially useless. The coolest custom program still needs electrons to run. Have a good power plan that does not rely on the venue providing power in the stands.
#3 Web based systems require the web. There are some awesome web based systems that teams ahve showcased, that they could not use in competition becuase lack of signal (poor signal, or venue not allowing wi-fi, or spontaneous field issues resulting in wi-fi shut downs or...) Have a back-up plan that uses paper and pencil.
#4 The top teams are easy to pick out, but sorting 20th to 28th best is often very difficult. Pay attention to everyone.
Unread 09-07-2012, 09:14
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Scouting
This is really the quote of the day. Finding that diamond in the rough or at least someone who can help a little in your strategy can be very difficult.
If you are planning on being a top 4 seeded team (or even picked in the top couple picks) you need to know this. The first pick is usually simple but coming back up that serpentine draft you can easily find yourself with nobody left worth picking if you are not diligent with this range of teams.
Unread 09-07-2012, 11:56
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: Scouting
I have a mundane question, but how do people handle actually getting the match scouting information from the match scouters to the drive team? (WiMax, etc technology is not so much in the cards for us right now.) Our scouting program is still pretty young and we could use some advice on streamlining this and making it easier for everyone.
Unread 09-07-2012, 12:07
BigJ BigJ is online now
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Scouting
In the past we have had some semblance of student analyst that can show the data to the coach+drive team in the pits pre-match. They normally gave the data and preliminary suggestions on what the opposing strategy may be and how best to go about defeating it.
Unread 09-07-2012, 12:11
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Re: Scouting
What we decided to do on 1403 this year in order to get the drive coach, myself, the necessary information was have the lead scouting mentor or the scouting captain come down to the pits before every match. We then discussed strategy, robots abilities, balancing, and other necessary topics.
Sometimes we ran into the problem where we had matches very rapidly and there was not enough time to return to the pits. In this case we just discussed multiple matches and it seemed to work really well for us.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 09-07-2012, 12:12
OliviaG's Avatar
No capes
AKA: Olivia Gifford
Team Role: Driver
Rookie Year: 2011
Re: Scouting
We bring a printer with us and hook it up to a robot battery, we print the sheets out with the full match results, then have a few extra scouts run it down to the drive team just before the next match, Its not as hard as it sounds. we keep a couple people as runners up in the stands with us, so the scouts don't have to leave their post.
I think that's what you were asking
Unread 09-07-2012, 12:18
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Re: Scouting
Our technology is literally "in the cards". We use a note card "pocket size" with the information on each team, and general strategy written on it. Then the scout or a runner brings the card to the coach after the preceding match.
Unread 09-07-2012, 13:52
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Re: Scouting
Another option that my team has done in the past is to have the drive coach be a scout. We usually send students out to coach, and it works well for us to just have 2 head scouts, one of whom takes a short break to come and coach the match and then goes back to work on match scouting for the next match.
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
  #15   Spotlight this post!
Unread 09-07-2012, 14:22
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: Scouting
We generate what are called "match sheets". It's a sheet with segregated into 6 boxes with a large picture of the team, the pertinent data on each team in a small table below each picture, and sometimes some hand written comments.
Sometimes they are printed in real time, other times we print blank sheets (just missing data) and the numbers are handwritten in. They are sent to the coach via a runner, or if there is a long break the coach will walk to the stands.
It's a nice format for displaying data and conveying who we are playing with/against for both ourselves and our partners.
[IMG] code is Off
