Go to Post I can't wait till FIRST starts giving anti-gravity kits inside the kit of parts. - Rob Colatutto [more]
Unread 09-07-2012, 22:14
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Press Fit
I had a few questions about press fitting, Specifically bearing's. Lets say I want to press fit a bearing into and 1/8" plate, the bearing's OD is 5/8. Do I drill a 5/8" hole? Because we tried that this year and we needed epoxy to keep it in place. Next question, Can you press fit into 0.09" sheet? or is that to slim? Any information is very appreciated!
Unread 09-07-2012, 22:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Press Fit
You should be able to press fit a bearing into a sheet that thin. To make a hole the correct size, get the exact size of the bearing, then subtract a few thousandths for the press fit, and make a hole exactly that size. Usually this requires using a reamer, or CNC machining.
Unread 09-07-2012, 22:38
MattC9's Avatar
Re: Press Fit
WE would be getting this laser cut, does that make a difference?
Unread 09-07-2012, 22:51
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Press Fit
This year we had our chassis water-Jet. There was no problem press fitting into it when i made the hole the exact size. NOTE: we also had it painted so that may have affected it). But when we got our off-season Chassis laser cut it was also press fitted and stayed perfectly (wasn't Painted). you shouldn't have a problem with 0.09", as long as you have a support all around the outside of the sheet-mteal and bearing, so that the metal doesn't bend. we had that happen, but we just hammers it back in place :/
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 09-07-2012, 23:03
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
Team Role: Teacher
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Re: Press Fit
Your would have to find out the kerf (width of cut) of the laser, and try to compensate accordingly.
You might run into problems with eccentricity of the circles being cut, and/or the accuracy and repeatability of the hole itself. Maybe try to get some samples cut and see if it's sufficient.
But the easiest method would be to just cut them undersize on the laser and then ream them as squirrel suggested. Anything that requires a precision fit should be drilled undersized and then reamed or bored to the final diameter.
Unread 09-07-2012, 23:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Press Fit
"A few thousandths" is FAR too much interference unless you have a really big bearing. Ideally, you're looking for something in the neighborhood of 4 ten-thousandths undersize for that size of bearing. You can get special undersize reamers to do press fit bores.
Let me ask, why do you need a press fit anyhow? In FRC, they're often more trouble than they're worth. Just make a good close slip fit and use part geometry to keep everything in place (flanges, shoulders, counterbores, snap rings, etc).
Unread 09-07-2012, 23:54
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Re: Press Fit
If the hole is just a little too loose sometimes you can make the hole smaller by whacking the edge of the hole with the ball end of a ball-peen hammer. That will result in a little bit of the edge sticking into the hole creating a slight interference.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 10-07-2012, 00:31
Big Ideas Big Ideas is offline
Mentor
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Rookie Year: 2007
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
Re: Press Fit
If you are looking at thin sheet (.062 or less) be aware that Flanged bearings sometimes have an undercut at the flange. It is possible that a hole of "proper" size is loose because the sheet falls into the relief groove.
Laser cutters and water jet cutters tend to have compensation for cutter kerf. You just have to make sure the part program uses the compensation. It would a shame to have nice holes well located by a CNC cutter and then have to try to keep the accuracy with an expensive hand reamer.
Also, look at parts from Spyraflo. These are self clinching self aligning bearings made to go into sheet metal (or thin wall tubing).
Unread 10-07-2012, 09:04
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
Re: Press Fit
to elaborate on sanddrag's post for a press fit it is a pretty simple process....look at this chart: http://www.turnedoutright.com/wp-con...rill-sizes.jpg
You select a drill size two sizes smaller than your desired hole size, go one step up to ream out the hole, and then press it on
for example: if I want to press onto a 0.250" shaft, I would go down two steps to a size D drill (0.2460"), then ream out the hole one with one size larger (0.2480"), then press....and you are done
Unread 10-07-2012, 11:49
MrForbes's Avatar
AKA: Jim
Re: Press Fit
Thanks for catching that, I've been working on cars lately....
Unread 10-07-2012, 14:15
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
Re: Press Fit
for example: if I want to press onto a 0.250" shaft, I would go down two steps to a size D drill (0.2460"), then ream out the hole one with one size larger (0.2480"), then press....and you are done[/quote]
0.250" is the same as an E drill. D is one size down. Two sizes down would be a C = 0.242"
Unread 10-07-2012, 17:41
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Press Fit
Before CNC this was done in any of several ways, from a file or sandpaper to a lathe with a 4-jaw chuck. It is not necessary for CNC equipment to be used.
Unread 10-07-2012, 19:50
MrForbes's Avatar
AKA: Jim
Re: Press Fit
Getting students to hand size a hole for a press fit bearing...now that would be a neat thing to see! We used to get to learn craftsmanship like that in machine shop class.
Thanks for the added info Don.
Another way to do it is to use a boring head on a mill.
Unread 10-07-2012, 22:25
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Press Fit
You can put a lightly loaded bearing in a .09" plate. If there is a lot of load you would want to use a doubler plate to get more bearing area. The difference from a loose running fit (clearance) to a too tight press is less than a couple thousands of an inch on 5/8" dia. Not a lot more if you are talking about a ball bearing with a OD of 1.125 or so.
Most unpracticed people cannot measure that with a micrometer. Drill tolerance is way more than that. Reaming tolerance is more than that.
What to do?
1) Use a new quality drill bit. Clamp the work well Probably be a little loose. Use bearing mount loctite to take up the clearance. I am not sure how well that will work with thin plate.
2) Drill it undersized and use an adjustable reamer get the right fit.
3) Drill undersize & use a deburring tool to get the right size. Only works with relatively thin bores.
  #15   Spotlight this post!
Unread 11-07-2012, 11:33
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Rookie Year: 2007
Peck will become famous soon enough
Re: Press Fit
he isn't talking a generic drill set, he is talking a real machine shop's drill set where they have the drills accurate to tenths of a thou. An E drill is a generic and it is typically .250, accurate to the thou. If you are pressure fitting with generics... be really careful and take plenty of measurements.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
