Go to Post I will follow FIRST's guidelines, as long as they conform with those of the English language. - artdutra04 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:31
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
WARNING...Dr. Joe's advice on the drill shaft is incomplete!
Posted by nuts4first.
Engineer on team #340, GRR - Greater Rochester Robotics, from Churchville-Chili and Nortel Networks.
Posted on 3/22/2000 10:13 PM MST
F L A S H B U L L E T I N
If you have taken Dr. Joe's advice by producting a replacement drill gearbox output shaft as described in 'Dr. Joes Drill Advice' step # 5 and as seen in the drawing 'Dr. Joes Drill Shaft' (in the lower right hand corner) be warned!
The drawing is missing a critical cut at the aft end of the shaft, in the middle of the 4 pins. If you are using this technique in your robot's drive system be cautious. A ~
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Q&A Discuss: Dr. Joe's Advice Work on new Boschs? CD47-Bot Extra Discussion 1 06-01-2003 22:18
Dr. Joe's Advice Work on new Boschs? Ryan Curry Motors 1 06-01-2003 12:30
WARNING...Dr. Joe's advice on the drill shaft is incomplete! archiver 2000 5 23-06-2002 22:31
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Shafting size, keyways, and Dr. Joe's Drill Shaft Alan Ing Technical Discussion 7 04-12-2001 10:30
