Go to Post CD threads are supposed to be about something? - Tim Baird [more]
Unread 17-07-2012, 17:10
Camren's Avatar
Camren Camren is offline
Mentor
FRC #3081 (RoBoEaGleS)
Rookie Year: 2011
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Metal Lubricants
Ok time for another installment of "what belongs in every teams toolbox" Todays topic; WD-40, JB-80, Grease, 3 in 1 sewing machine oil, or other? Here are my thoughts.
At robotics:
WD-40: Used for lubricating our pneumatic cylinders, chain and lubrication on other metal on metal rubbing points that are hard to get at.
Grease: Used for metal on metal rubbing points that are easy to get at and will be rubbing together for long periods of time (ie the whole season)
In the auto shop use:
JB-80: used to prep pneumatic tools and lubricate stubborn rusty bolts
Grease: used on the key grease points on every car
Personal use:
WD-40: used on my bike chain
sewing machine oil: used to maintain my hand tools and i also use it for my home appliances with any sort of gear box (most commonly my paper shredder)
So what do you guys and gals on chief delphi use at robotics, work and or home as lubricant.
Unread 17-07-2012, 18:11
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Metal Lubricants
Originally Posted by Camren View Post
At robotics:
WD-40, or "Water Displacement" is not actually a lubricant; it's designed to displace any water in a mechanism so it can be greased with actual lubricant. Only once have I ever actually used WD-40 to displace water.
White lithium grease.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 17-07-2012, 18:18
Camren's Avatar
Mentor
Rookie Year: 2011
That is very interesting I didn't know that. I have been using it on my bike chain for years.
Unread 17-07-2012, 18:29
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
see attachment
Unread 17-07-2012, 20:09
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
I can't speak so much for robot chains but I can tell you that you should absolutely never lubricate a bike chain with WD-40. It will strip any existing lubricant from the chain and leave you with metal-on-metal. Not to mention that it will leave behind a paraffin residue that will muck up with dust and dirt faster than any other product. The only time you can use WD-40 on a chain is if you're trying to clean rust off it, after which you should de-grease and clean it and then properly lubricate it.
Originally Posted by Ether View Post
see attachment
Not sure where you got that picture, but even WD-40 themselves say that its not meant for bike chains. http://www.wd40.com/about-us/myths-legends-fun-facts/
Unread 17-07-2012, 21:40
ezygmont708's Avatar
ezygmont708 ezygmont708 is offline
FAIL = First Attempt In Learning
AKA: Zygmont
FRC #0708 (Hatters Robotics)
Rookie Year: 2007
ezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant future
This year our team tried something a little different for lubrication. We used Dupont Teflon Chain Saver. Very little mess and a little bit of this amazing stuff goes a long way. In addition to using this on chain, we put in our gearboxes and even the gearing in our shooter head. Plays nicely with polycarbonate.
http://www2.dupont.com/Consumer_Lubr...ubricants.html
E. Zygmont
Team Lead - Team 708 Hatters Robotics
Hatboro- Horsham Senior High School - Horsham, PA
Unread 17-07-2012, 23:09
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
JB-80 is an excellent all around lubricant for more than pneumatic tools and rusty bolts.
Any of the Justice Brothers products for lubrication is great to use. They have an excellent chain lube, and white lithium grease( worked great in the AM super shifter gear boxes we used this year). They also have a silicon spray that is useful in applications that do not need the extreme lubrication that grease and spray lubricants add.
FRC Team 3659 Mighty Patriots- Mentor/Drive Team Coach(2015-)
FRC Team 3345 Metal Jackets- Build Team Mentor (2012-2014)
FRC Team 2969 Hurricane Robotics - Lead Mentor/ Drive Team Coach (2011/2012 seasons)
FRC Team 399 Eagle Robotics - Student Alumni (2002-2005)
2011 Alamo Regional - Xerox Creativity Award(2969), Referee
2012 Alamo Regional - Quarter Finalist
2012 Lonestar Regional -Semi-Finalist
2012 Lonestar Regional -Xerox Creativity Award Winners
Unread 27-07-2012, 16:53
DonRotolo's Avatar
Back to humble
FRC #0832
In the automotive world, we consider WD-40 a reasonably effective adhesive. It makes things slide for a little while, but then it gums up and gets sticky.
We use Mobil Velocite Spindle Oil #6 for a light lubricant, Mobil Vactra #2 Way Oil for a medium lubricant (both are used on the lathe too), WalMart spray white grease for a light grease, and Mobil synthetic grease (not sure of the number, but recommended by BaneBots to lube their planetary transmissions - it's dark blue) as a heavy grease.
Chains get light oil, shafts with bearings get light grease, transmissions get heavy grease, everything else is a best guess.
Unread 27-07-2012, 20:12
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
WD 40 has some lubricants in it and can be used for the task, but its really not very good for it. My favorite general purpose oil is 3 in 1 oil, and a lighter oil for finer mechanisms(bought it originally for a camera shutter mechanism, but I now use it on bikes chains and other stuff) For those I use NYOIL.
KK4KQO
http://voltair.us
Too many projects, too little time.
Unread 28-07-2012, 00:39
Team 4057 Team 4057 is offline
FRC #4057 (Klamath Basion Robotics)
Team Role: Leadership
Team 4057 is an unknown quantity at this point
I love lubricants but i have to say is don't put to much on the part. I have ruined more than one bike chain by over lubing it and having dirt cling on and work there way into the joints.
Unread 28-07-2012, 03:33
We use this as well. Works great for all our applications.
I was introduced to it by RC, owner of West Coast Products. He also suggests this as the lubricant of choice for WCP products. The McMaster part number is also listed.
http://wcproducts.net/how-to-gears/
Unread 28-07-2012, 05:29
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
My dad and I both are avid bicycle mechanics... and we use:
WD-40: My dad uses it for chains. I use it for chains once in a while. Also used for reviving dried seals in Presta valves and pike pumps.
ATF - I buy whatever happens to be cheapest (currently dextron-mercron mix). I use it for chains via an oil can. I also use it in 3 speed hubs, in freewheel mechanisms, and as a general de-gunker for cleaning old gunked up bearings and the like. I even have a plastic crystal light tube of it that I soak really crusty parts in. Once in a while it gets used as a cutting oil.
White Lithium grease- Used for packing loose/caged bearings, press-fit things (headset cups, square taper cranks, etc), sliding clamps (stems and seatposts), and heavy threads (bottom bracket cups, freewheels, track cogs/lockrings, crank threads). Also used to pack coaster brake hubs and to coat new brake/shift cables.
Not quite a lubricant, but PB-Blast often gets used for dealing with rusty things...
Back in my days as an FRC student, 3-in-1 was used by both former teams to cut stuff. Both teams used whatever grease happened to be donated for transmissions and the like; 1747 used white "food grade" grease; 2783 used black "ford/lincoln" grease. We had no issues either way...
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 28-07-2012, 10:14
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
WD-40 is not a very good lube. It is primarily Stoddard Solvent/paint thinner, which evaporates. What's left does gunk up. It does make a good grease cutter.
For light lubrication, air tool oil isn't bad. It should have rust-preventative additives.
My recent favorite is Fluid Film. While primarily intended as a rust preventative, it does a decent job of penetrating and lubricating, doesn't dry out and is somewhat waxy. It contains Lanolin. Some use it on bike chains. I spritz it on battery terminals to prevent corrosion.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
