Go to Post But when it comes down to it, the best teams usually end up winning regardless. - Cory [more]
Unread 18-07-2012, 12:20
Poneil Poneil is offline
Poneil is an unknown quantity at this point
Inertia issues
Need some wisdom regarding reflected inertia. I've got a lead-screw electric
actuator, stoke length = 30". Lead = 0.1", vertical load = 1000lb's. 5 sec move time.
Question: Is calculating the reflected inertia the same proceedure as that for
a lead/ball screw linear slide ( ignoring any side loads )?
Unread 18-07-2012, 12:27
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Re: Inertia issues
What do you mean by reflected inertia?
-- Len
Unread 18-07-2012, 16:00
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Inertia issues
-- Len
http://www.diequa.com/download/articles/inertia.pdf
I didn't know what it was either, but I learned a lot about it there. I still don't know enough to answer your question, but maybe someone else here can. I've never done one of these calculations with one of our robots before, but after reading this I may start for chain/cable driven mechanisms that require precise motor control. So I guess it wasn't the programmers' fault all along?
Layman's terms/"TL;DR": the amount of inertia the motor shaft sees transmitted from the load. Modeled ideally by Load Moment of Inertia/[Mechanical Advantage]^2. Useful when precise motor control (i.e. speed or position control) is necessary and the motor is not rigidly coupled to its load. A large difference between the reflected inertia and the motor shaft inertia can explain why some arms or other mechanisms always seem to oscillate rather than behave as controlled. Not exactly Layman's terms, but I think most people on ChiefDelphi would understand most of that.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Last edited by KrazyCarl92 : 18-07-2012 at 16:11. Reason: Added summary of Reflected Inertia
Unread 18-07-2012, 18:46
Levansic's Avatar
AKA: Len Evansic
Re: Inertia issues
Good find!
Inertia comes into play when something experiences acceleration or a change in velocity. Usually the effects of inertia are noticed when starting or stopping movement. In the initial post, there is inertia of the original 1,000 lb. mass, and a rotational inertia of the screw and the motor. Reflection implies bouncing off of something, which has little to do with inertia.
With a linear rate of 6" per second vertical, the inertia is no match for the force of gravity, if the actuator was required to start or stop. Elasticity in the system will play a much greater role, and here is where inertia will have an effect.
Assuming no friction between the worm and the rack, the shaft needs a torque of approximately 510 oz.-in. to oppose gravity and only a little more at 60 rpm to lift the load. There are a few 2012 KoP motors/gearboxes that theoretically can supply this torque at those speeds. In the real world, there is friction, and elastic deformation of all components, which both increase the torque required. All of the real world drags likely dwarf the inertia of the motors, in this application.
-- Len
Unread 18-07-2012, 18:55
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Inertia issues
IReflection implies bouncing off of something, which has little to do with inertia.
"Reflected inertia" is a term of art used in mechanical engineering.
In the present context, it means the effective inertia of a load as seen at the motor.
Unread 27-07-2012, 16:42
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Inertia issues
Sort of like an 'effective inertia', which is different because of the mechanism in-between?
So as you gear the load down (motor turns faster than load moves), the reflected inertia would be lower at the motor (because the mechanical advantage is greater than unity) right?
Unread 27-07-2012, 17:17
Ether's Avatar
Rookie Year: 1969
Re: Inertia issues
Right.
