Go to Post Be realistic in your goals, and relentless in hitting them. - IKE [more]
Unread 21-07-2012, 12:46
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
2012 IRI Elimination Selections
Code:
1 - 341  2056 148  2168
2 - 624  118  2949 1714
3 - 68   469  125  1676
4 - 3322 67   111  217
5 - 2826 1114 4334 245
6 - 1023 33   51   330
7 - 2590 973  543  1538
8 - 16   359  233  2834
* The webcast was blurry so I had trouble reading these numbers, please correct if you have this info.Thanks
No declines throughout. Eliminations will be very interesting as always.
Unread 21-07-2012, 12:47
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Re: 2012 IRI Elimination Selections
2590 is 7 alliance capt
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Code:
3 - 68   469  125  1676
4 - 3322 67   111  217
6 - 1023 33   51   330
7 - 2590 973  548  1538
8 - 16   359  233  2834
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 21-07-2012, 12:48
Ultimatum's Avatar
Ultimatum Ultimatum is offline
Student at Purdue
AKA: Stuart McCrorie
FRC #1646 (Precision Guessworks)
Rookie Year: 2011
Ultimatum is an unknown quantity at this point
#8 backup is 2834.
http://www.indianaroboticsinvitational.org/
Note #8 back-up is wrong.
2011 - 2014: 3501, Firebird Robotics, Student
2014 - ????: 1646, Precision Guessworks, Mentor
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
543 is 548
2638 is 1538
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 21-07-2012, 13:38
Andrew Lawrence
Posts: n/a
Wow. Alliance 1 seems really OP (and not just because they have 2056). They'll be pulling off triples every match, have strong scoring, and an awesome hybrid. The only problem I see is all 3 are very strong offensive bots, so a well played defensive strategy (maybe by that of 125?) can leave them with a field without balls to score.
Alliance 2 also looks like strong scorers. Pretty much the same as alliance 1.
Alliance 3 looks amazing. 68 and 469 will dominate the scoring, and if 125 plays the feeding and starvation tactic they've done all day, they'll surely be able to shut down most alliances. Triples will be near for sure here. Although in the event the alliance needs to pull 125 in for scoring, they may find their scoring won't go up as fast as it did before. 1676 is a good backup bot, very accurate, but like I said in an earlier post, their shooting can sometimes take a while, especially when being compared against high caliber teams such as 118 and 469.
Alliance 4 is interesting, to say the least. In the past, an alliance with 67, 111, and 217 would annihilate any opposition, however here these teams seem to be pretty well averaged. Alliance captain 3322 is pretty good as well (although I haven't payed too much attention to them).
Alliance 5 seems very capable of pulling off some high scores and triple balances. The Simbots and ATA are together again, and having worked through regionals and champs together will make them a good combination on any alliance. Add in 2826 and 245 as the backup and you have a very solid alliance.
Alliance 6 will be pretty competitive. All very solid scoring machines, all very good balancers. I see 330 being pulled in more often solely due to their strong drivetrain and amazing defensive strategy.
Alliance 7 will be the one alliance that'll go big or go home. 2590 is a great scorer. Like I said before, 973 is one of the most versatile bots at IRI they'll be able to score, feed, defend, and balance. They'll definitely be pushing around their opponents with that Emperor Swerve drive of theirs. 548 plays a lot like 330 does, although they're a bit better at scoring, with the sacrifice of the defensive power 330 has. They'll be scoring well nonetheless. I see 1538 coming into use as one of those well played backups bots. Very strong scorers, and most of the time very accurate.
Alliance 8 consists of some really good teams. World Champion team 16 will most likely be taking on their usual role of feeder/defender on this alliance, and they'll do it well. One of the best teams when it comes to ball collection, especially with their Bomb Squad swerve they've perfected over the years. 359 came up from the shadows and surprised everyone at IRI with their scoring power and balancing capabilities. 233 will be another main scorer on this alliance, hopefully being able to stay on their own side and dunk basketballs while 16 feeds them. Backup 2834 won't see too much action unless one of the other 3 bots breaks down.
So with that in mind, here are my predictions:
Alliance 1 vs Alliance 8.
Alliance 1 will own in hybrid mode, however, as soon as 16 gets over to the red side they'll wreck their havoc and leave the red alliance without a ball to score. Most likely then 2056 will go over and act as a feeder/defensive bot with 341 and 148 scoring quickly and accurately like they always do. Things will go back and forth, with most likely a double triple, ending in a close finish by alliance 1. Possibly 3 matches will ensue, but I think the winner will be the red alliance. This'll be one of the hardest matches for alliance 1. The finals are probably the only harder ones.
Alliance 2 vs Alliance 7.
Alliance 2 has 118, something no other alliance does. However, with 973's swerve, they'll be playing hard D for sure, and 118 won't do well under the hounding. 548 and 2590 will score throughout the match, but ultimately alliance 2 will come out victorious due to a triple balance that alliance 7 will attempt but fail. In the end alliance 2 is victorious.
Alliance 3 vs Alliance 6.
Alliance 3 has a lot going for them. 2 amazing scoring machines and a feederbot that can single handedly shut down alliances. The only way alliance 6 has a chance is to pull in 330 and have them hound 125 and keep all balls on the blue side. It'll be tough for the blue alliance to win, since most likely they won't bring in 330 until later, resulting in alliance 3 completely owning alliance 6. After 2 matches alliance 3 will be victorious.
Alliance 4 vs Alliance 5.
If there were ever a time here that blue would beat red, it'll be Alliance 4 vs Alliance 5. Alliance 4, while cluttered with well-known powerhouse teams, is average amongst the competition and most likely won't pull off anything too spectacular to bring them through the win. The blue alliance will have 2826 and 1114 scoring like they always do, hopefully with 4334 feeding them. A triple balance is almost certain with 1114 on the team. Alliance 5 will be the winner here. Possibly 3 matches.
Alliance 1 vs Alliance 5.
Miss OP Wrangler will once again dominate the scoring here, outclassing the blue alliance on every aspect of the game. Some defense will be showcased, but the difference will be negligible, ending in an all-out offensive brawl, resulting in a victory for alliance 1 both rounds.
Alliance 2 vs Alliance 3.
This'll be a close match. 624 and 118 will be the dominant scorers on their alliance, but nothing they'll do will be enough to beat the power alliance of 68, 469, and 125. 125 will clear the blue side of the field, 68 and 469 will score all the balls, rinse and repeat. Alliance 3 wins.
FINALS: Alliance 1 vs Alliance 3.
This will be one helluva match, quite possibly one of the best matches in all of Rebound Rumble. To be completely honest, I don't know what way it will go. But I know this: The results of the match will rely completely on the actions of 2056 and 125. If 125 does a good enough job of starving the first alliance of balls to score, then Alliance 3 will barely take it. If 2056 is able to keep 125 at bay, Alliance 1 will steal the victory. There's a 99% chance that there will be 3 matches.
Of course, I could be completely wrong. Round one is starting. Let's find out!
Unread 21-07-2012, 14:16
stundt1's Avatar
stundt1 stundt1 is offline
Steve
FRC #4930 (Electric Mayhem)
stundt1 will become famous soon enoughstundt1 will become famous soon enough
Wow what a match alliance 1 just lost daisy tipped over .
Whats the results form the first 4 matches?
Steve
-Programming Mentor
- Team 578 Alumni
Unread 21-07-2012, 14:24
Ultimatum's Avatar
Student at Purdue
Rookie Year: 2011
The 5 alliance just beat 4 alliance in 2.
1st alliance beat 8th alliance in 3.
The 2 alliance just beat 7 alliance in 2.
3 is up 1-0 on 6.
Unread 21-07-2012, 14:56
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Rookie Year: 2012
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
After watching most of qualifications I'm excited for the 1st, 2nd, and 5th alliances...amazing groups of teams can't wait to see it all shake out!
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 21-07-2012, 15:00
Ultimatum's Avatar
Student at Purdue
Rookie Year: 2011
The quarterfinals are done. The matchups are:
1 vs. 5.
2 vs. 6.
Unread 21-07-2012, 15:02
Andrew Lawrence
Posts: n/a
1 beats 5. 2 beats 6. 1 beats 2.
Unread 21-07-2012, 15:04
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
The way 1 is playing, I'd say 5 beats them out, and 2 beats out 6. The finals would be tough to determine, but I'd give 118 the benefit of the doubt.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 21-07-2012, 15:06
Andrew Lawrence
Posts: n/a
Mine is in the event Daisy stops tipping every time they attempt a triple, and 2056 stops walking into situations they can't get out of. Mainly, if Daisy tips, 5 takes them out for sure.
Unread 21-07-2012, 15:07
Division by Pirates
Rookie Year: 2012
I feel the same way, the 5th seed is very good, and the 1st seed is underperforming...this will be a very exciting end to IRI
  #15   Spotlight this post!
Unread 21-07-2012, 15:24
Ultimatum's Avatar
Student at Purdue
Rookie Year: 2011
The 1st and second alliances just both won their first match. Both games were really close, and came down to the bridges.
