Go to Post I am a human wiring diagram, how can i help you? - Jeffy [more]
Unread 23-07-2012, 20:57
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: Snap Rings Or Shaft Collars?
Unread 23-07-2012, 20:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: pic: Snap Rings Or Shaft Collars?
More info is needed on how the shaft was loaded and what caused the failure.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-07-2012, 22:58
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
It does not look like fatigue to my admittedly under-trained eye. What are the details around the failure?
Unread 23-07-2012, 23:37
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
2024 or 7075?
Unread 24-07-2012, 00:17
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Looks like it might have been... too little detail to tell for sure.
IMHO snap rings are the way to go unless what is going on the shaft already is in essense a shaft collar (like a keyed sprocket).
What WILL cause severe problems under torque is drilling a hole through a shaft and putting a bolt/cotter pin. Just ask anybody who saw the 1747 bot at Cage match 2008 before elims. We sheared a steel shaft that drove the slide lift on the manipulator right where it was drilled for a drive sprocket. had we keyed the shaft and used the gear like a shaft collar it wouldn't have failed.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 24-07-2012, 07:18
Took the broken axle shaft to a Metallurgist this morning, he described a normal cycles to failure type of break. Two cracks formed 150 degrees apart from irregularities in the snap ring groove and spread toward the center. He suggested changing alloy from 2024 to 7075 for added strength. We’ve played a lot matches in the Michigan District system, Championships and two off season events. Bot got a new set of pneumatic tires for IRI which increased load on an already weakened axle shaft.
Unread 24-07-2012, 08:54
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
One understated feature of IRI is robot lifetime. By the point the competitors get to IRI, some robots have seen 100-120+ matches and are now playing some of the hardest matches they've ever seen. Things start to fail that you don't necessarily expect and team's aren't necessarily ready for.
Thanks for sharing. Hopefully your team got something out of a rough situation.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 24-07-2012, 11:04
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
If the snap ring groove was cut in a torqued or stressed part of the shaft it was bound to fail and the design should be reconsidered.
As some have said, more context is needed, and a clear picture would be nice (macro mode FTW).
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 24-07-2012, 15:04
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
I would just switch to a steel shaft and call it done. I don't think the minimal weight savings you get from aluminum shafts is worth the risk. We have used aluminum shafts in the past, and while we didn't see any catastrophic failures like you show here, we bent a few of them.
In response to your original question, usually snap rings are more reliable than shaft collars, but they do weaken the shaft. You want to avoid transmitting torque past a snap ring groove if possible. Generally I like to use snap rings on the ends of the shaft to keep things on, and spacers in the middle of the shaft where it will see torque loading.
Unread 24-07-2012, 15:09
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
I am presuming, based on the description, that this is:
http://www.andymark.com/product-p/am-0396.htm
I don't recall how the Toughbox gears are arranged, but I don't believe that they transmit torque across the snap ring groove -- the short end is there for a bearing and for the encoder. It's probably difficult to find a different application for this shaft that puts torque on both sides of the groove.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 24-07-2012, 18:23
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Team Role: Coach
Rookie Year: 2000
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
Totally agree with Rob:steel shaft way to go. Also, when grooving for snap rings
one should refer to machinist handbook.
Unread 24-07-2012, 20:55
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
This general topic has been discussed several times before. General theme: Use the right tool for the job. If you understand what material types can be used where, you can get away with a robot that has no business weighing less than 120 lbs. Not saying we have it all figured out. We still have a lot to learn, but here is what we have learned during our short time in FRC.
We just started using the FEA tools embedded in Inventor this last year and this helped shave our sheet metal thicknesses by at least 20 %. We also found a couple problems with fatigue and were able to fix it before we even manufactured a single part.
2828 converted over to 7075 AL hex shaft in 2010. We have used .375, .5, .625 and .75 for anything from gearbox shafts and cantilevered axles to arm joints and shooter axles. All of these had e-clip style snap rings as the main retaining fastener. We had one issue this year that was similar to the OPs shear at the groove, but it turned out to be that the material used was accidentally 2024 instead of 7075. After the switch, no problems.
I highly suggest purchasing from onlinemetals.com. They have a great selection, fast shipping and prices that are hard to beat.
If anything, please don't "just go to steel". In most cases it isn't necessary.
Unread 24-07-2012, 21:37
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Agreed, there are very few instances where you need a steel shaft in FRC.
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 24-07-2012, 22:11
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
Where do you get your .375" 7075 hex bar? Onlinemetals does not supply any in this size. Fry Steel's website says that they have it, but when I called them about a month ago, they said that they didn't have any in stock and didn't have any plans to stock it.
Thanks for your help!
Website
Facebook
  #15   Spotlight this post!
Unread 25-07-2012, 01:38
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
One of my favorite ways to retain elements on shafts is to just use spacers stacked up between them. Yes, you usually have to manufacture them yourself, but they can make assembly and disassembly much easier. They maintain components the correct distance apart without a long alignment process (shaft collars) or weakening the shaft (retaining clips). In my designs, there is usually just a stack up of spacers and components captured between two bearings, or there is a shaft collar that you just press up against one end of the stack up.
On a side note, if you do decide to use shaft collars, use two piece ones. It can be a life saver to be able to drop a shaft collar off a shaft to get at something rather than disassemble a whole mechanism to get it off.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
