Go to Post I think that everyone should just take a step back and look at the whole picture, FIRST is a family, not an organization full of regions, we all try to help each other, not 'cause it benefits us, but because it's graciously proffesional. - Mike Schroeder [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:34
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Drill motor mod.
Posted by Justin Stiltner.
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
Posted on 3/27/2000 8:56 PM MST
Dear everybody,
Has anyone managed to remove the pinion from the shaft of the drill motor or the fisher price motor? if so I would be very thankfull if you were to post just how you did this. Does anybody evean know how they are attached? it looks like they are pressed on but that doesent seem correct.
Thanks for the help and see you at nationals.
Justin Stiltner
Team 388
Grundy High School
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Pinions are pressed on.
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 3/28/2000 4:46 AM MST
In Reply to: Drill motor mod. posted by Justin Stiltner on 3/27/2000 8:56 PM MST:
The pinions are pressed on.
We have never pressed off the Fisher-Price pinion, but have often pressed of the pinion on the drill motors.
Basically, we mount the motor in a plate and used 2 big screw drivers to pry off the pinion.
If you are not going to try to use the pinion afterwards, you may try using a dremel to gently cut off the pinion. You will have to be careful not to damage the motor shaft, but it can be done. If you use this method, be sure to tape up the motor first in order to keep the dust out of the motor.
Good luck.
Joe J.
#0047 (ChiefDelphi)
Re: Pinions are pressed on.
Posted by Thomas A. Frank.
Engineer on team #121, The Islanders/Rhode Warrior, from Middletown (RI) High School and Naval Undersea Warfare Center.
Posted on 4/12/2000 3:13 PM MST
In Reply to: Pinions are pressed on. posted by Joe Johnson on 3/28/2000 4:46 AM MST:
Greetings;
Our machinist showed me a little trick...
He took a piece of steel, thin enough to fit between the pinion and the motor top, and cut a slot in it slightly wider than the shaft. He then slid this plate in, supported it on each side in an arbor press, and used a pin punch to press the motor out the bottom (catch it before it hits the floor!).
Works as well with a vice and a hammer, if need be.
We needed to press off both pinions, and reinstall the drill motor ones on another shaft.
Tom Frank
[IMG] code is Off
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
