Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 04-08-2012, 13:26
pmccorm2005 pmccorm2005 is offline
pmccorm2005 is an unknown quantity at this point
Quesiton on Pitching Machine Motor
Hello...
I stumbled across this site when googling how to decrease the speed of a pitching machine. Not sure this is best place to ask but here goes... I own this machine: http://baseballpitchingequipment.com...-w-ball-feeder
Although it has a speed control on it, even at the lowest speed, it pitches wiffle balls too fast. I'm trying to determine if there is something I can do to lower the speed without having to break the unit apart and do stuff (I'm certainly not qualified to do that).
Any ideas? Thanks very much!
Unread 04-08-2012, 14:06
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
FRC #0862 (Lightning Robotics)
quinxorin will become famous soon enough
Re: Quesiton on Pitching Machine Motor
There are two ways to do it. The first, and "best" would definitely involve taking the machine apart and doing stuff, specifically altering the gear ratios. However, that isn't too practical anyway, given the machine's compact construction.
The alternative would be to limit the power getting to the machine, most likely with a resistor. Use a multimeter to measure the current going to the motor, and multiply that by the voltage (110 or so) to get the power. Then, install the appropriate resistor in the plug wiring to decrease the power - guides for the math are available online. The decrease in speed will be about proportional to the decrease in power. You'd likely need a rather large resistor, though, or you'll see it catch on fire.
A more efficient way, but probably more expensive, would be to install a transformer to decrease the voltage. This won't waste energy like a resistor will (and therefore, won't catch on fire), but would be more expensive.
No, this isn't exactly the right forum, but we do know quite a lot about this sort of thing.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 04-08-2012, 14:38
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: Question on Pitching Machine Motor
Hold on, I'd be a little careful before installing a series power resistor or a transformer. The exact kind of motor in the machine is very important here. Many AC motors will burn out if operated at a reduced voltage via series power resistor or transformer.
Jim
Unread 04-08-2012, 15:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Absolutely. I've checked a couple other models from this company, and they all state it's a DC motor. Unfortunately, I've been unable to find the manual for this exact product.
It is also meant to be used with a rollingpower battery pack.
Best guess is that it's a DC motor, however, modify at your own risk.
Unread 04-08-2012, 15:40
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
FRC #0973 (Greybots)
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
From the OP's link:
The powerful A/C motor throws lite-balls at variable speeds up to 60 miles per hour.
Your best and safest bet, while (comparatively) expensive, is a VFD or Variable Frequency Drive. You will need to find one appropriate for your motor's HP.
Automation Direct sells one for $100.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Electrical Engineer
AKA: Jim Wilks
The OP's link says "powerful A/C motor" and that the unit runs on "A/C Power".
Jim
Unread 05-08-2012, 13:45
DonRotolo's Avatar
Back to humble
FRC #0832
First off, welcome pmccorm2005 to the ChiefDelphi forum! While we're not really into pitching machines, we do know a lot of things about a lot of things.
You see, we're a bunch of geeks (and proud of it!) that work with an organization called FIRST Robotics (www.usfirst.org), dedicated to inspiring kids to better understand match, science, and technology. We build robots to help accomplish that goal. Kind of like wiffleball for the mind.
Anyway, to your question: If this is in fact an AC (alternating current, like what comes out of the wall) motor, the only real way to vary its speed is to vary the frequency of the AC going to it (and, as already noted, these start at about $100). BUT since it is already variable in speed, it is far more likely that while the unit runs on AC, the motor control is something else and not a variable frequency drive system. Meaning an external controller is more likely to just get the pitching machine angry and let out the magic smoke.
Before you start getting out screwdrivers and soldering irons, the first step should be to contact the folks who make this unit. They may have some simple suggestions for slowing the pitches down even further than what you have now. Ask for the engineering manager, or the technical support team, explain what you have and what you want to do, likely they'll be able to help. If you don't understand what they tell you, write it down, tell us, and we can help there.
Good luck!
