Go to Post Common sense can take you a long way!!! - ClintDog [more]
Unread 05-08-2012, 00:14
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Rookie Year: 2012
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
Autodesk Inventor Question
Is there any method used to make a mirrored assembly that is derived from another assembly?
My setup:
"DriveModule (Assembly)" -> One drivetrain, or one half of my drive base
Drivetrain Assembly -> After placing "DriveModule" I would like to both mirror it (I know how to mirror) and make the new mirrored assembly update whenever I edit "DriveModule." from what I've read this is an obvious feature in Inventor 2012, but I am using Inventor 2011. Can anyone help me with this?
FRC Team 987 - It's not enough
Unread 08-08-2012, 20:13
Rookie Year: 2012
Re: Autodesk Inventor Question
SOLVED:
Here is the solution if anyone else needs it:
-After you create the assembly (in my case the left drivetrain) create a new PART.
-Go to manage->insert->derive and select your assembly. There are extra options that will change depending on your needs in this window.
-Go to the options tab
-select "mirror"
Now you have a second "assembly" to place in your final robot assembly. Since it is derived from the first (left drivetrain) changing the first assembly will update both. This is very useful, especially for those designing symetrical components.
Unread 09-08-2012, 08:12
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Good guy OP.
Posts solution to his problem when no one answers with a solution.
Thanks,
Sunny G.
1648: 2013-2014
5283: 2015
