Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
  #16   Spotlight this post!
Unread 12-08-2012, 11:57
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Chains
Originally Posted by PAR_WIG1350 View Post
I would imagine a large zip-tie would also work if the tension is low enough (with safety glasses in case of high-energy zip-tie failure events ).
I'd like to note that should you go with this then be ready to explain to an inspector what you're doing. I dunno if it was just the inspector, but boy did he give us some trouble in St. Louis for using zip ties...
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #17   Spotlight this post!
Unread 12-08-2012, 12:29
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Chains
Originally Posted by DonRotolo View Post
Slightly off topic: Regarding installing master links, has anyone used a pair of "pliers" (somewhat modified with hooked tips) that hook into links at the ends so the chain can be pulled tight enough to insert the master link?
akoscielski3: That explanation was fine, but on small sprockets it can be difficult, and often side access is tight near the sprockets. We used that technique for our #25 chain that's out in the open.
There is a tool like you describe. We use one like the "B" style on that page.
We also use the Dark Soul Chain Tool for 25 chain, and found an equivalent for 35 chain. We seam the chain outside of the robot, then put the axles and sprockets in with the chain in place.
Kettering Motorsports
  #18   Spotlight this post!
Unread 12-08-2012, 13:51
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Re: Chains
We have both tools and are using them. the problem is to lock the connecting link - very small parts that need plier and hands but not enough space for the hands... I realized that our problem was the gap between the 2 sheetmetal, we had 5 centimeters gap but in other drivetrains that were posted here I saw a lot more.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
  #19   Spotlight this post!
Unread 14-08-2012, 01:21
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Chains
So THAT'S what that tool is used for! I saw something like that in our cart for years, but never had a clue what it was.
Our solution to working with chains in tight places was a set of small fingers (mine) and adjustable chain tensioners. I don't know why the design worked the way it did, so I'll try and dig up some pictures, but all you had to do was loosen or tighten a bolt at the end of the drive train (we used extruded aluminum, and the ends were left open) and it would move the axle/sprockets to pull the chain tight. The chain was initially seamed outside of the chassis and then put in at the same time as the sprockets and axles, but if it needed to be removed at competition for whatever reason, loosening the chains helped to make the masterlink more accessible - if the axles were close enough together, we could pull the linked section up through the top of the chassis and take off/put on the link with plenty of space.
I don't know how this would work for 4WD (shown in your picture) as opposed to 6WD (what we used), but I'm sure that something similar could be designed to suit your needs.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #20   Spotlight this post!
Unread 14-08-2012, 09:27
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Chains
One way I always worked around using a tool like this was to assemble the masterlink on a sprocket. You would pull the chain tight, and slowly rotate the wheel/sprocket to a point where the links could easily stay on the sprocket without much effort. Then assemble the masterlink with the chain ends on the sprocket, and poof.
Of course this assumes you have access to the wheel/sprocket, which we usually allowed for.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
  #21   Spotlight this post!
Unread 14-08-2012, 20:31
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
Re: Chains
in the photo attached you can see how we run our chains with a integrated supershifter on the sheet metal. to take out or replace the chain all we have to do is take out the screws that are holding the tension (red arrows in picture) and the chain has plenty of slack to get at a masterlink under the robot. the chain rubs on a circular piece of Delrin to reduce friction and noise.
Name:	photo 3 (2).jpg
Bacon
  #22   Spotlight this post!
Unread 14-08-2012, 21:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Chains
apalrd, imagine tool "B", but with pliers handles instead of a turn knob, that's what I'm wondering about.
Zip ties would be fine too, but I just hate to waste zip ties...
Yarden, now I understand the problem. One possible solution: Train a student on Master Links. Have them remove and install a master link several hundred times, in increasingly difficult positions, always with tools instead of fingers. I am thinking that with a lot of practice someone could get quite good at it.
Inserting the master link itself seems easy enough, if the chain is tight enough.
Then there is the cover plate - not difficult, but you cannot allow it to fall off.
Then, the lock clip. Practice that move a few hundred times and you'll get good at it.
Maybe a job for a freshman?
